Inserting hardware devices
On digi 001 from what I get you can insert 4 stereo or 8 mono using the outputs/inputs on the back of the interface.When I get digimax in a couple of weeks will the hardware insert capabilities double as well? 8 stereo,16 mono. Also what is the difference between the $799 version of digimax and the $1299 Version?
Learning,learning,and more learning! THANKS TO THE DUC! ****OptymusBlu**** |
Re: Inserting hardware devices
You can use all available I/O (as defined in the I/O setup dialog) for inserts.
Rail
Oh ok great.Thanks a lot rail!
Inserting a hardware compressor on the master buss | Johnrg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-16-2011 01:53 PM |
inserting hardware across part of a surround aux | MixerGuy | Pro Tools TDM Systems (Mac) | 7 | 09-27-2010 09:38 PM |
Inserting New Audio | shultzee13 | Pro Tools M-Powered (Win) | 0 | 01-29-2008 01:41 PM |
Inserting hardware into the Protools mixer... | nwilliams | Pro Tools TDM Systems (Mac) | 3 | 05-01-2005 02:24 PM |
inserting | lcouri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-23-2002 06:18 AM |
