Multiple Playback Channels Without Being Assigned
If this is not the correct place for this post, the moderator can feel free to move it...
I am seeing a problem where Pro Tools outputs are assigned to analog hardware outputs 1-24 to feed an analog console. So far, so good...but Sometimes we will also see every Pro Tools output ALSO appear on outputs 1-2 without being assigned to do that. Has anybody seem something similar? Thanks in advance... Networker Pro Tools HDX 12.5.2 on El Capitan. |
Re: Multiple Playback Channels Without Being Assigned
hi
I posted this a while ago. Could be related, could be different, but the setup is similar. Only thing is that in our case it is only during record with countoff/metronome. Dan http://duc.avid.com/showthread.php?t=389078 Sent from my iPad using Tapatalk HD PS in the post i mention a workaround that worked for him |
Routing multiple channels at one | Kenmillerjr | macOS | 3 | 02-21-2012 09:53 PM |
multiple channels | panda234 | Pro Tools 10 | 1 | 10-22-2011 03:16 PM |
Recording multiple midi drum channels to multiple audio tracks? | ewan.mcghee | MIDI | 7 | 07-18-2011 01:46 PM |
Multiple Outputs in i/o assigned to A 1-2 | KingFish | Pro Tools TDM Systems (Mac) | 6 | 05-13-2009 05:47 PM |
XPand! – How to use it on multiple channels? | nilsk | Virtual Instruments | 3 | 08-23-2008 06:52 AM |
