Old 12-02-2010, 08:28 PM
edadema edadema is offline
Banned
Default PT 9 Crashes All The Time When Working with VI's
I have been Mixing a lot and 9 seems pretty stable there, but I haven't push 9 creatively yet. So far a BIG FAIL
The Way I make money is Producing Music for others and Mixing. I am now in writing Mode. Last night I worked on a session that crashed about 8 times. I also Got the Gray Curtain of Death like 3 times before completing. It is such a Creative Buzz Kill. It makes me so Angry!!!!! I must lash out. You release 9 charges us more than ever and Don't improve VI handling for SH%T
Every Time it crashes I will update this Thread!!!
This is what I am using in my Template that I start from. All VI's are up to date!!
PT9
HD2
Mac 2.4 2010 8 core
OS 10.6.5
VI's
BPM 1.5
Transfuser 1.3
Nexus 2.2
Kore 2.12
Maschine 1.5.1
Reaktor 5.5.1
Massive 1.1.5
Structure 1.1
Hybrid 1.6
Midi
Axiom Pro 49
MPC5000
Blofeld
SE1x
Matrix 1000
I do use more VI's as the session gets going but this is my starting point. Am I kidding myself that PT will ever be a writing tool?
Here we go
DTS do you want me to post the Crash repot everytime too?
Old 12-02-2010, 09:08 PM
Banned
Default Re: PT 9 Crashes All The Time When Working with VI's
Surprise it Crashed!!!!!!!!!!!
Old 12-02-2010, 11:27 PM
djdopus djdopus is offline
I feel your pain, at least you have managed to get PT9 to see your interfaces.
maybe try disabling some of the instrument tracks individually (just for a while) to determine which one is causing the crash, then write it to audio.
not the best but maybe a work around..
Old 12-03-2010, 01:11 AM
GS-DK GS-DK is offline
My world.....
Creative = Logic or Cubase or Live
Mix and Audio: ProTools......
Old 12-03-2010, 01:20 AM
crizdee's Avatar
crizdee crizdee is offline
PT9
HD2
Mac 2.4 2010 8 core
OS 10.6.5
VI's
BPM 1.5
Transfuser 1.3
Nexus 2.2
Kore 2.12
Maschine 1.5.1
Reaktor 5.5.1
Massive 1.1.5
Structure 1.1
Hybrid 1.6
For a start you are using an unsupported operating system 10.6.5 has not been qualified and i'll guarantee most of those VI's have not been tested either on 10.6.5 Yes lots of people will say it shouldn't be a problem but there have been issues with incremental updates in the past, and we have had to skip those versions because of issues.
You need to check your crash reports!! and check which thread has crashed??? it might tell what has caused the crash and it might just be one of the plugins and NOT pro tools itself.
Crash logs can be found in system drive/users/your name/library/logs/diagnostic reports. it will say which thread has caused the crash. so copy paste that thread here!!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-03-2010, 05:54 AM
axiom axiom is offline
I can tell you that Maschine and other NI plug-ins cause me more crashes than any of the of the others in your list. I can go over a week of constant use with no crashes, then add Maschine into the mix and inevitably PT will eventually crash soon after. I've noticed that it's not a good idea to browse through sounds or kits in Maschine while the transport is running.
I compose exclusively in Pro Tools and generally have little trouble most of the time. I run Bidule and VEPro on slave machines for most of my instruments.
Will Loconto
www.WillLoconto.com
Old 12-03-2010, 06:00 PM
bonfi64 bonfi64 is offline
only one VI in a session and possibly avoid kontakt and sci-fi plugs like NI
they are the top in the crashing list, your story is exactly like mine:
i stay on PTHD and my dealer when i talk about the continuos crash told me to upgrade to PT 9, well i will wait till 12 if they still there!!!
Old 12-03-2010, 06:14 PM
formfunction formfunction is offline
Huh?
Old 12-03-2010, 06:41 PM
Banned
Chris
Don't know how to read this so I will post it
Process: Pro Tools [183]
Path: /Applications/Digidesign/Pro Tools/Pro Tools.app/Contents/MacOS/Pro Tools
Identifier: com.digidesign.ProTools
Version: 9.0 (9.0f121)
Code Type: X86 (Native)
Parent Process: launchd [139]
Date/Time: 2010-12-02 01:47:50.182 -0800
OS Version: Mac OS X 10.6.5 (10H574)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: 0x000000000000000d, 0x0000000000000000
Crashed Thread: 53
Thread 0: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x93e8514e semaphore_timedwait_trap + 10
1 Maschine.dpm 0x53bd15df NI::GP::HEvent::wait(int) + 79
2 Maschine.dpm 0x545559ce SyncedThreadingJobManager::Schedule(SyncedThreadin gJob*) + 446
3 Maschine.dpm 0x545e5726 BEngine::IO_ZLEAddSegment(int, int, int, int, float, bool) + 918
4 Maschine.dpm 0x549ea515 KONTAKT_KIL_INT::InstanceInt::AddZoneLevelEnvelope (int, int, int) + 1077
5 Maschine.dpm 0x54dadf4c NI::GB:ESC::Zone::updateEnvelope(int, int) + 252
6 Maschine.dpm 0x54dae5b5 NI::GB:ESC::Zone::loadSample(NI::GP::FileName const&, bool) + 1141
7 Maschine.dpm 0x54dd34c2 boost::detail::function::void_function_obj_invoker 1<boost::_bi::bind_t<void, boost::_mfi::mf2<void,
Old 12-03-2010, 06:43 PM
Banned
Maschine was the first thread is that how you can tell
How are AAX VI's working out in PT11? jumle AAX Plug-ins 6 06-24-2013 01:45 PM
HD 10.3.2 crashes with VI's! lownotesinc Pro Tools TDM Systems (Mac) 3 11-15-2012 11:09 AM
50 Spectrasonics VI's, 50 NI VI's and 50 structure all in one pro tools session crizdee Pro Tools TDM Systems (Mac) 11 04-03-2010 09:03 AM
PT 8.0.1 Crashes all time nguetecho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-04-2009 08:37 AM
Crashes all the time ep Digidesign Hardware & Software 5 05-04-2001 09:57 AM
