Old 11-29-2011, 09:44 PM
WernerF WernerF is offline
Default Playlists sometimes don't follow groups.
In 10 HD sometimes, actually more often than not, when I switch between playlists in, let's say a drum group, only the track that I am using to select a different playlist will change to the new playlist. The remaining tracks in the group will not switch to the selected other playlist. Anyone else seeing this behavior? Just trying to see if it's a 10 bug or if it's specific to my system.
Old 11-30-2011, 04:44 AM
Bushpig Bushpig is offline
Default Re: Playlists sometimes don't follow groups.
Werner,
Hi. I don't use playlists very much, but the other day I created a single duplicate playlist on each of 4 separate pairs of BV's (each pair it's own Mix+Edit group) and one of the pairs refused to switch back and forth properly, but the other 3 worked fine. IOW's all 4 pairs were created and manipulated individually (ie:not as a group of 8 tracks) at the same time and therefore should have behaved the same, but didn't.
Like I say, I don't use playlists that often, so I'm not sure if this is a legacy problem as I seem to remember this being a major topic of discussion when PT8 came out. In fact I suspect you were involved in that discussion(?). I skipped PT9, so I don't know if that version was OK.
Hope that helps.
Cheers
Steve Bush
www.music180.com/pros/5887
MacPro 4.1 (Nehalem) 2.26 8 Core, OSX 10.6.8, PT10HD, 14 Gig RAM, 192, Sync I/O, Midi I/O.
Old 11-30-2011, 07:49 AM
Steve, thanks for the info. I skipped 9 as well but, as you say it is apparently a legacy bug, I never actualy had the problem in 8. But man can it screw things up if you're not paying attention!
Anyone else have this problem now?
Old 11-30-2011, 02:23 PM
BaileyBass BaileyBass is offline
Yikes.. I would have hoped they would have this fixed. I documented this on the DUC a couple of years ago, back in PT8. Very frustrating....
Old 12-17-2013, 10:09 PM
Timm Spinn Timm Spinn is offline
I am still having this problem in 10.3.7. I've tried it in several different sessions, and it happens in all of them! Every other group function works fine, even duplicating a playlist. But I just can't switch between them as a group. I have to do each track at a time! Brutal! Please let me know if anyone has found a fix.
Note: I didn't group the tracks until after tracking was done... Meaning, I made each playlist on each track individually when tracking. (my first time doing a full 10 mic drum session.) Please help!
PT12 HD, Focusrite Scarlett 18i6
www.timmspinn.com
Old 12-18-2013, 12:34 AM
Drew Mazurek's Avatar
This is the problem. Moving fwd, if you avoid this, you should be fine. Don't have a solution for your problem now though.
www.drewmazurek.com
Old 12-18-2013, 03:47 AM
joachim's Avatar
joachim joachim is offline
Could that be a Mac only problem ?
In Win 7, selecting one audio track of a group and switching playlist does switch also the playlist of other audio tracks within that group,
regardless of grouping the audio tracks prior or after recording.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 12-19-2013, 07:10 AM
Thanks for the info Drew. I could, however, swear that I have experienced this behavior on tracks that were grouped prior to recording them as I always create the drum groups in the template before starting the recording of an entire record. I could be wrong on the details though. It could be that the problem has occurred only on the odd session where the groups were only created after the tracks were recorded onto. I will do a test and report back.
Old 12-19-2013, 08:35 AM
Russ M. Russ M. is offline
I seem to remember this in V7 and maybe V6 as well.
I'm still running V7.4.2 and wonder if I should go to V10..
I'll check this out when I get a minute.
Since I usually either flip single playlist or the entire session by holding the option key and haven't flipped groups in a while I haven't run into it lately but I do seem to remember this happening.
Old 12-19-2013, 09:18 AM
Yes, in PT V7.4, if I record 4 tracks then make 4 new tracks and record those then make a group of them they will not flip playlist for all 4 tracks even when grouped.
However, if I record 4 tracks then group them and make 4 new tracks and record on them while grouped they will flip playlist for all 4.
Clip Gain Needs To Follow Groups DougBull Pro Tools 10 3 11-18-2011 03:46 AM
Groups follow global JohnCatlin Pro Tools TDM Systems (Mac) 1 09-24-2010 05:05 AM
SOLO's SHOULD FOLLOW GROUPS!!!! Kourquie Pro Tools TDM Systems (Mac) 25 10-01-2009 09:49 AM
Q . About Groups Follow Global borism Pro Tools TDM Systems (Mac) 2 03-22-2007 01:41 PM
Playlists, multiple takes - follow edits? MoreMeintheMonitors Tips & Tricks 1 04-24-2003 02:07 AM
