Windows Vista Home Edition 32 bit & Pro Tools 8.0.1 LE?
Just picked up the Digidesign Eleven Rack with Pro Tools 8.0.1 LE! All my computers are 32 bit Running Vista Home. I can't even get the program to install. I plan to call tech support on Monday but was hoping there was a download to fix this? Any help or advice would be great.
Thanks |
Re: Windows Vista Home Edition 32 bit & Pro Tools 8.0.1 LE?
Sorry ...
Hangs up at around 10% c:\Program Files\Digidesign\Pro Tools\Pro Tools.dll Computer: Processor:Intel (R) Core (TM)2 CPU [email protected] GHz 3326 MB Ram 32 bit operating system Vista Home Premium OS Digidesign Eleven Rack with bundled Pro Tools 8.0.1 LE software |
According to what I can find on the support from Digidesign the computer is compatible?
Can't tell until you post a Sandra Report.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
+1 on the 'Do IT!!!' ,,,,,,,Its free (SANDRA) very simple,,, and a lot of real cool, real knowledgeable guys here ready to help!!! Only takes one, over looked, little, thing to stop everything and shut you down. And you could be up and running in minutes,,, or at least know what you need,,,, without waiting on the phone for,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ever! (Well,,, at least a long time!!!)
Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
Going to run it and post!
SiSoftware Sandra
Computer Model : GM5446E Workgroup : WORKGROUP Host Name : CustomClimat-PC User : Custom Climates Inc Processor Model : Intel(R) Core(TM)2 CPU 6320 @ 1.86GHz Speed : 1.87GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing Computer Mainboard : Intel D945GCF BIOS : Intel Corp. CF94510J.15A.0038.2007.0226.1646 02/26/2007 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.25GB DIMM DDR2 Chipset Model : Gateway 2000 82945G Processor to I/O Controller Front Side Bus Speed : 4x 267MHz (1GHz) Total Memory : 4GB DIMM DDR2 Memory Bus Speed : 2x 401MHz (802MHz) Memory Module(s) Memory Module : Samsung M3 78T2953CZ3-CE6 1GB DIMM DDR2 PC2-5300U DDR2-666 (5-5-5-13 3-18-5-3) Memory Module : Nanya M2Y1G64TU8HA2B-3C 1GB DIMM DDR2 PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Memory Module : Samsung M3 78T2953CZ3-CE6 1GB DIMM DDR2 PC2-5300U DDR2-666 (5-5-5-13 3-18-5-3) Memory Module : Nanya M2Y1G64TU8HA2B-3C 1GB DIMM DDR2 PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Video System Video Adapter : NVIDIA GeForce 7650 GS (12 PS3.0, 5 VS3.0 450MHz, 256MB DDR3 2x398MHz, PCIe 1.00 x16) Storage Devices WDC WD5000AAKS-00TMA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) (D:) HY 131MB (USB) : 125MB (G:) Hitachi HTS541212H9AT00 (120GB, USB, 2.5", 5400rpm) : 112GB (F:) Generic USB SD Reader (USB) : N/A (H:) Generic USB CF Reader (USB) : N/A (I:) Generic USB SM Reader (USB) : N/A (J:) Generic USB MS Reader (USB) : N/A (K:) TSSTcorpCD/DVDW TS-H652D (ATA33, DVD+-RW, CD-RW, 2MB Cache) : 8GB (E:) Disk : N/A (L:) Logical Storage Devices Recovery (D:) : 10GB (NTFS) @ WDC WD5000AAKS-00TMA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Hard Disk (C:) : 456GB (NTFS) @ WDC WD5000AAKS-00TMA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Pro Tools LE (E:) : 8GB (CDFS) @ TSSTcorpCD/DVDW TS-H652D (ATA33, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (L:) : N/A @ Disk Removable Drive (G:) : 125MB (FAT) @ HY 131MB (USB) Gateway PMD01120 (F:) : 112GB (NTFS) @ Hitachi HTS541212H9AT00 (120GB, USB, 2.5", 5400rpm) Removable Drive (H:) : N/A @ Generic USB SD Reader (USB) Removable Drive (I:) : N/A @ Generic USB CF Reader (USB) Removable Drive (J:) : N/A @ Generic USB SM Reader (USB) Removable Drive (K:) : N/A @ Generic USB MS Reader (USB) Peripherals LPC Hub Controller 1 : Gateway 2000 82801GH (ICH7DH) LPC Interface Controller LPC Legacy Controller 1 : Winbond WPCD374L/376I/377I Audio Device : Gateway 2000 82801G (ICH7) High Definition Audio Serial Port(s) : 2 Parallel Port(s) : 1 Disk Controller : Gateway 2000 82801G (ICH7) Ultra ATA Storage Controller Disk Controller : Gateway 2000 82801GB I/O Controller Hub SATA cc=RAID USB Controller 1 : Gateway 2000 82801G (ICH7) USB Universal Host Controller USB Controller 2 : Gateway 2000 82801G (ICH7) USB Universal Host Controller USB Controller 3 : Gateway 2000 82801G (ICH7) USB Universal Host Controller USB Controller 4 : Gateway 2000 82801G (ICH7) USB Universal Host Controller USB Controller 5 : Gateway 2000 82801G (ICH7) USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : Gateway 2000 TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Samsung CLX-3170 Series (600x600, USB, Colour) Printer : Roland GX-24 (1016x1016, USB, Colour) Printer : Amyuni Document Converter 2.51 (1200x1200, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP psc 2400 Series (1200x1200, USB, Colour) Printer : HP LaserJet 2410 PS (600x600, Parallel, Colour) Printer : hp psc 2400 series (USB, Colour) Peripherals Media Player : HY (124.7MB) Media Player : () Media Player : () Media Player : () Media Player : () Network Services Network Adapter : Intel(R) PRO/100 VE Network Connection Wireless Adapter 1 : Broadcom 802.11g Network Adapter (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows Vista Home 6.00.6000 Platform Compliance : x86 Windows Experience Index Current System : 4.8 |
My installation halts here after this message and just plain shuts down the installation process?
Feature Transfer Error: Feature: Documentation Component: Documentation – LE Hardware File: E:\Pro Tools LE Installer \ data2.cab Error: Data Error (cyclic Redundancy Check). |
I don't know exactly what is causing your problem, but things that I see that could be problematic are all of those USB drives/USB Mem Card readers, etc.
I suggest that you unplug, uninstall, disable all of the USB drive struff and try again. You don't have to unistall the USB controllers. Another thing that caught my eye is the 1394 controller. If you cannot verify that it has a TI chipset, then turn it off and get a 1394 card with a TI chipset (ex. SIIG 2 or 3 Port). If you have power management turned on, set it so everything is "Always On". Disable any anti-virus software that may be running. Once you get PT to install, you likely will have to do most, if not all, of the Vista tweaks to get PT to run reliably. Digi has posted the Vista tweaks on the DUC. Good luck, Greg
Protools PC, i9 10990, Gigabyte X299 mobo, 64 GB ram, EVGA Nvidea GT 720 TI video card, Win 10 Pro, PT Ultimate (Native) 2024.3.1, HD Omni, HD I/O 16x16 . |
Pro Tools 9 in Windows 7 Home Edition 64bit Sound Problem | Thanks4yourhelp | Windows | 7 | 03-11-2011 04:38 PM |
Pro Tools 7.4 LE not working on Vista Home Edition | FlyingPanda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-23-2011 10:37 PM |
Please Help me!!! I can't setup PT 8 (Win Vista Home Edition) | lopez_316us | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-23-2009 12:08 PM |
vista home edition and pt7.4 | craigstauffer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-12-2008 06:16 AM |
vista home edition and pt7.4 | craigstauffer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-11-2008 09:03 PM |
