Old 08-13-2023, 09:57 PM
▲ит╰•_•╯ ▲ит╰•_•╯ is offline
Default The "Bounce Mix... This Is NOT My Drive" Mystery
After finishing a mastering session, I went to bounce the final to my session drive by selecting File/Bounce Mix... and under Location, I selected the Directory radio button for my File Destination, like always. However, this time the directory tree below the Choose button was listed as someone's network dropbox that I do not know. I've been on PT since version 4 and I've not seen any bug that would cause something like this so I have concerns.
Now, I know that if I open someone else's session on my rig, it will have that person's last saved directory tree populated to the Bounce Mix location field (that needs to be fixed…security issue). The perplexing part is that I created these mastering sessions on a newly purchased computer with new ssd drives that I formatted myself, saved the sessions only onto my drives, and the sessions have never been shared or have touched a collaboration network. I found this person's directory tree on 3 other recent back-up sessions for other masters thus far. The only session that I have opened that is not mine on this rig is the PT intro demo session that I opened during the search for other sessions with this person's directory tree attached.
With that said, my question is this:
Is there ANY way a different directory save location can populate to the destination field on a session previously saved to my local drive directory without physically typing it in the destination field…or has someone been saving my work to their network drive?
Old 08-13-2023, 10:21 PM
Top Jimmy's Avatar
Default Re: The "Bounce Mix... This Is NOT My Drive" Mystery
Perhaps when the PT installer was compiled, the folder path from this persons computer was the last path used. I wouldn’t read any more into it than that.
James Cadwallader
Old 08-14-2023, 01:50 PM
Top Jimmy's Avatar
The question to ask yourself is, “How can his folder path show up on your system?”
To be blunt, it can’t unless it exists on your system. If it doesn’t exist on your system you’re tilting at a windmill.
James Cadwallader
Old 08-14-2023, 02:42 PM
Thank you for your further explanation and patience, Top Jimmy...now this makes complete sense. A good example of why you are a moderator! Cheers!
"Commit" or "Bounce" Non ARA 2 Melodyne Track? Sparky1 Pro Tools 6 09-30-2022 10:52 PM
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? ZerglingPhilosophy Getting Started 1 09-02-2022 03:43 PM
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
"Bounce To Disk" Track is "Lower in Volume" LSNY Pro Tools 12 18 06-05-2017 08:45 PM
"Track count per drive" mystery david kowalski Pro Tools TDM Systems (Mac) 1 04-08-2002 09:23 AM
