Old 03-29-2001, 12:38 AM
Gremz Gremz is offline
Default Re: No Sound Output
bump..
Old 03-29-2001, 12:49 AM
Default No Sound Output
Due to matters beyond my control, I was forced to reformt my system drive and start all over again.
In the process, I've lost the ability to monitor any computer system sound through my 001. I've reinstalled all my software, made sure all the right extensions are in place, removed the Digi control panel, and still no go.
I'm running OS 8.6., with 5.1LE on a 256 meg of ram G4 (YIKES).
The following is located in my extensions folder:
Digidesign direct I/O
Digidesign DSP Manager
Digidesign Output Drivers "B"
Digidesign StreamManager
DigiDesign INIT
I have no Digidesign files in the control panel.
I do not have the option to select "Digidesign" in the "Sound Output" section of the Monitors and Sound control panel.
I called Tech Support and the Tech racked his brains trying to figure it out, but no luck.
We must have missed something, as this used to work fine before the big hard drive reformat party. Now I can't get the option to switch between different sound outputs.
Help!
Gremz
Old 03-29-2001, 06:41 AM
CLanger CLanger is offline
Try reinstalling the Digi control panel. I use 9.1, but this worked for me when I couldn't get sound out from Mac apps through my AMIII card.
Or... try removing the 001 card, restart, shut down, put card back in, restart.
(just a thought)
Chris
chris@castle-productio
ns.com
[This message has been edited by CLanger (edited March 29, 2001).]
Chris
[email protected]
Old 03-31-2001, 07:29 AM
The funny part is that it used to work just fine before the crash.....I'm not sure what I'm going to do if I can't get this to work. I have to have non-PT audio pass through the 001 in order for my studio operations to work.
Thanks CLanger for the advice.
Gremz
Old 03-31-2001, 10:37 AM
Well, I tried pulling out the digi interface card and reinstalling it, but it didn't make a difference.
I wonder if OMS has anything to do with it?
Gremz
No sound output? Soundburst macOS 2 12-01-2011 06:48 AM
No sound in output flyingrabbit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-19-2009 09:12 AM
can't get G4 to see 001 as a sound output hay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-02-2006 01:22 PM
sound output Ben Jenssen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-06-2002 12:35 AM
Help with Sound Output RockToTheTop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-03-2002 11:38 AM
