Bounce sounds worse than Session using WAVES
I am noticing a big difference in audio quality between my Bounce files and when playing back my sessions. The sessions sound great, and as I listen to the bounce process as it is bouncing to disc, all seems good to go. But when I play back the bounced file (using Soundjam, for instance), it sounds pretty thin and slightly distorted - a big difference from what I heard in my session while bouncing to disc. It seems like something fishy is going on with the bounce processing. I am using Waves NPP 3.0 for all my processing.
I'm the recording engineer for my church and we produce cassette albums (among other things) to our congregation. I record straight to a Tascam on-the-fly CD burner. During the mastering process (in post production), I insert an L1+ on the master bus, and a Q4 and C1 on the stereo track containing the "message". I use the L1+ in such a way that the peaks just tickle the activation of the limiter, usually only resulting in about 2-3 dB of limiting. The wall is set to about -.3 dB. IDR is 16bit, type 1, normal. On the C1, I use a mild threshold and compression (3:1) with fast attack. The only EQ'ing I am doing is a Hi Pass filter with the Q4. Again, while in the session, it sounds pretty good, but the bounced file sounds very noticably different. When I bounce, I set it to stereo interleaved, 16 bit, convert during bounce. Has anyone else noticed this difference? Or is it just me? Gremz |
everytime i bounce a track on pro tools 10 windows 7 the quality gets worse ! | cassie11 | Windows | 4 | 11-28-2012 08:52 PM |
waves automation problems seem to be getting worse... | jmattchan | Post - Surround - Video | 6 | 05-24-2009 07:11 PM |
mp3 bounce artifacts - "slow" worse than "fast"?? | Dave B | Pro Tools TDM Systems (Mac) | 3 | 07-07-2004 09:23 PM |
Does Waves 3.0 sound worse than 2.8.1 to anyone else? | Mt.Everest | Pro Tools TDM Systems (Mac) | 23 | 05-10-2001 08:56 AM |
WHY PT sounds thinner and worse than Capricorn and and and??? | 666 | Tips & Tricks | 19 | 03-11-2001 10:13 PM |
