Old 02-03-2019, 03:11 PM
ozzlvlosis ozzlvlosis is offline
Default Re: Upgraded to RME Fireface/No MIDI
Weird thing...in midi ox control panel I changed a sound on my motif.
Old 02-03-2019, 04:03 PM
Southsidemusic's Avatar
Check that ”local On/Off” ln the Motif is set to either or, can’t remember if it should be Local On or Local Off but look for that setting ln the Motif Menu and try both On/Off and see if you get a signal.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 02-03-2019, 05:17 PM
Local on or off won't affect what the OP is seeing. All that affects is whether the Motif's keyboard directly triggers the sound generator(s) in the Motif or not. You should still be able to get MIDI into PT.
I would suggest the OP does a full reset to the Motif and start from fresh. I think something got mucked up in the Motif - possibly some sysex messages did things in.
Old 02-03-2019, 07:52 PM
Weird thing is it was working fine a week ago with the remedy babyface. Now with the fireface it's only audio
Old 02-03-2019, 07:57 PM
Sardi Sardi is offline
Did you check your settings in Audio/MIDI setup like I mentioned at the start of the thread?
If you change MIDI interface and don’t update your settings in Audio/MIDI, it’s not going to work.
It’s the first thing I would be looking at, hence why I suggested it.
Old 02-10-2019, 12:16 PM
It was the MIDI cables. Thanks to all for your help and insight
Old 02-10-2019, 04:14 PM
Bad MIDI cables or incorrectly connected?
Old 02-10-2019, 06:12 PM
I would say incorrectly connected. MIDI cables are some of the most robust cables out there; it's not like a guitar cable that is constantly moving around (or Roger Daltrey's mic cable )
upgraded to 12.8.2, now no midi tracks will play mfaith2 Pro Tools 12 1 08-31-2018 06:51 PM
Upgraded and Lost MIDI centuryson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-13-2010 08:55 PM
Upgraded to PT8 and now can't send MIDI to external synth Odms 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-14-2010 02:06 AM
Upgraded Pro Tools - MIDI tracks gone.? tommydigiowen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-06-2008 11:22 AM
Finally upgraded to 5.1.1, but now MIDI's gone wacko! Dean Bohana 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-05-2002 06:41 PM
