waveshell RTAS horror!
removing waveshell RTAS removes the horror!
everything normal with no waves! everything SLOW SLOW SLOW with waves! im talking 1 1/2 min to load ANY audiosuite plug in! every time! launching PT takes an extra 2 min! remove waves, all is well! WHUTS UP WIT DAT FIXIT DIGI !! (waves isnt going to) p.s. MORE TARCKS! (boo?) ------------------ www.mp3.com/xtac for the faint of goth |
Re: waveshell RTAS horror!
Coaster, that's funny. I had the opposite problem with v2.8. I had to use the dongle and it took me a minute and half for PT to boot. Once I upgraded to 3.0, it now boots in about 15 seconds. It is great! and no dongle!
I did notice that NPP 3.0 is more power hungry. The meters are noticablely sluggish with only 3-5 tracks being used. Gremz |
coaster check it out>>> i had the same 1.1/2 to load any audiosuite
plugs >>>was very bad>>> i made system format updated OS to 9.1 and now it takes>>>>>> 4 secs !!!! to load any audiosuite >>>this is for real . i made several tests >> "small" plugs takes 3 secs sansamp , trueverb , takes 4 secs maybe you should think about doing some system format hey on PTt's boot its the same 1 min or 2 min i dont know ,,, i start to load the pgm and go to do coffe or some thing P.S made the tests with " swatch "beat" " good luck
Oh, it gives off an orange cloud of light, that just flows right out over the sea... wow! |
*sigh*
yes, i noticed my buddy's g4/450 with os 9.0.4 did not have the strange audiosuite behaviour mine is having. i have an 8600/300 with 8.6. i will have to do testing with os 9 to see if my old machine will even run it. odd thing is, his g4 does not get a heck of a lot more plug ins than mine, nor redraw the screen any faster in pro tools. graphics software is another story (SMOKE!) i guess its FIXIT COASTER! |
It's unfortunate that Waves seems to have so many problems. I just got the exploding sound fixed, and now it's something else.
I've gotten used to PT taking 1-2 minutes to launch, because I've had the Waves Bundle since day 1. I've never known anything different. I guess it's something that's liveable though. The real problem seems to be waiting 1-2 minutes for an audio suite plug-in to open. Am I hearing you guys right on that? I've never had that problem, but I would be upset if I did. Hope it gets resolved for you. |
Check these out:
http://www.digidesign.com/ubb/Forum25/HTML/001540.html http://www.digidesign.com/ubb/Forum16/HTML/006229.html http://www.digidesign.com/ubb/Forum16/HTML/006370.html http://www.digidesign.com/ubb/Forum1/HTML/002007.html and in the Waves-forum: http://www.audioforums.com/forums/Fo...ML/000125.html Have fun !-( not) ------------------ Arno Peeters Tape TV Productions |
Arno, since your above Digi links don’t work, I thought I’d check my bookmarks, and guess what - NONE OF THEM WORK. I appears the changes Digi made to to DUC have wiped out all our bookmarked links.
------------------ bassmac |
Sorry those links don't work as written. If you replace "www" in them with "duc" they will work. Apparently when we moved the DUC to it's own server not all of the links redirected properly.
------------------ Bruce Paine Digidesign We'll work on making an automatic re-direct that will forward the previous "www.digidesign.com/ubb/..." links to "duc.digidesign.com/ubb/..." [This message has been edited by Digidesign (edited January 25, 2001).]
Administrator Avid Pro Audio Community |
Coaster--I have an 8500 with a G3/400mhz cpu.
Also have waves NPP I & II 2.8.1(2.9.1beta wave shell) with dongle. The beta fixed the "exploding sound" as you probably know. I am running 8.6 because the ram usage is much less than 9... It works great. I can open an L1 and 1 Realverb--1 Dverb--1 truverb and still use several eq's and Comps with DAE set on "4". My audiosuite open in 5 seconds--L1-RenComp-All EQ's also--Realverb-Autotune. I am afraid to go to 3.0 because I am warm and fuzzy with current setup... Sandman--What are the details of your setup? ram-cpu-etc...
I Seek the Holy Light... Isaiah 40:31 72 Strat with single 2-Blade pickup PTLE 10.3 LE 2-SSL Alpha Channels - 1 SSL G-Compressor Apogee Rosetta 200 - Z-Systems Opti-patch Lexicon MPX-G2 Guitar Processor - .003r Command 8 - Roland JV1000 + Triton Rack FOCAL TWIN 3way speakers + JBL Q108MK11 Bottom 2-52 jax MilSpeck Patch Bays 2-22" Apple Cinema Display's Allen & Heath 16ch Mixr **Currently = 11-1-12 2 CD's Released-1-2003-2-2012 Worship ROCK |
hey guitates
G4 450mhz >> 256ram >>> boot HD >>> OS 9.1 waves gold pack 2.8.1 >> Waves ShellRTAS 2.9.2b2 after upgrading my OS system to 9,1 the audiosuite deley simply vanished >>i stll cant belive it , , , test OS 9,1 ------------------ bom-shenkar
Horror/Gore (not Al) | hki | Post - Surround - Video | 9 | 09-08-2008 04:18 PM |
002 Horror | Thomas Gessner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-13-2004 11:59 AM |
The Sound of Horror | K.B. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-07-2004 06:09 PM |
OHHH the horror | alienzombe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 06-04-2002 11:13 PM |
waveshell RTAS bundle | sammi10000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-07-2001 09:51 AM |
