Old 06-03-2020, 01:48 AM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
Default ProTools crashes after offline bounce
Hello, since 2020.x protools crashes at the end of the offline bounce... the bounced file itself is ok and solid but PT gives the spinning beachball and never recovers.
Normal online bounce works like it should, I'm using pt2020.3 and upgraded to 2020.5 but still the same crash.
Anyone a solution ?
OS 10.15.3
PT 2020.5
Mac 7.1
PT Ultimate 2024.03.0, Avid S1, Eucon 2023.11
16" MacBookPro (2023) M2 Max 12-core, 64gb Ram, 1Tb SSD, OSX 14.4.1
MTRX v.2.4.2.2 + dante card + madi baseunit + optical SFP 1300nm
MTRX-II v.1.0.5.2 + TB3 + 1x AD mic 8ch + 1x DA 8ch
MOM v.1.0.1.4 by DAD
Genelec 1237A Sam, Avantone active mixcubes
LA2a (1968), 1073 pre/eq, Neve RNHP, Wacom Intuos Pro
Furman P1400 AR E Power conditioner
Live-rack:
1x HD Native TB, 4x 192 I/O (64ch AD)
8x Yamaha HA-8 micpre, Rosendahl mif4,
Genelec 1031A, Presonus Monitor Station
Old 08-20-2020, 03:47 PM
RussP RussP is offline
Default Re: ProTools crashes after offline bounce
Anyone a solution ?
OS 10.15.3
PT 2020.5
Mac 7.1
Did you figure out a solution to this? I have the exact same problem
Old 08-20-2020, 04:13 PM
Anyone a solution ?
OS 10.15.3
PT 2020.5
Mac 7.1
Did you figure this out? I'm having the same exact problem
Old 09-03-2020, 01:47 AM
No, still crashes after offline bounce 🤬
Live-rack:
Old 09-03-2020, 09:20 AM
moogboy100 moogboy100 is offline
In my experience a particular plugin is always to blame for this. Thats why upgrading Pro Tools has no effect. You just have to figure out which plugin.
🖥️ Pro Tools Ultimate 2023.12.1 | Mac Studio M1 Max (64 GB) | Ventura 13.5.2 | Focusrite Red 4Pre
💻 Pro Tools Ultimate 2024.3 | MacBook Pro M3 Pro (18 GB) | Sonoma 14.3
Old 09-03-2020, 09:48 AM
morronga morronga is offline
I have the same issue but only when I'm bouncing to MP3
Old 09-03-2020, 09:57 AM
I keep my plugins updated, got even a folder with all the download links from different companies.
But even if I remove all non avid plugins it still crashes after bounce.
But these days the rig is silent since corona stepped into our country. 🤬
So no bounces made since april.
I will check 2020.9 which is released today.
Live-rack:
Old 09-03-2020, 09:58 AM
One way to troubleshoot this is to make each row of inserts inactive(one row at a time) and run off-line bounce. That way you can narrow down to a plugin in that row and from there, its easy to re-activate plugins and find the culprit (assuming it is a plugin, which I also suspect).
Old 09-03-2020, 12:08 PM
lumcas lumcas is offline
I had exactly the same problem, not a biggie but it was really annoying when I had to make several bounces in a row. Signum Audio Bute Surround Suite 1.4.0 (only in expanded view) was to blame in my case. Well, at least I know what was causing the problem and over time I've got used to close the plugin GUI before bouncing to audio...
Old 12-30-2020, 04:05 AM
cerisaie's Avatar
cerisaie cerisaie is offline
Glad I'm not alone guys ! This is really annoying, I'm having this when bouncing Offline in mp3 (Rough mixes) sometime pro Tools unexp quit sometime, as you mention, got the spinning ball and have to force quit !
If you found a solution please let me know !
I'm with the last version Pro Tools Ultimate fresh install recently very new rig with Mtrx Studio and all "official" plugins here
Standard configuration no Hackintosh here (was before) Mac Mini Intel 6 cores and 64G of ram
Owner of www.studio-up.be
Pro Tools 2020.11 HDX Sonnet Thunderbolt 3 Rack enclosure with a Mac Mini 2020 I7 64Gb of ram And Avid Dad Mtrx Studio …
Can anyone help? Protools stuck on offline bounce mixedbyfabian Pro Tools HDX & HD Native Systems (Mac) 3 11-26-2019 10:14 AM
Session crashes when trying to Bounce offline WildHoney Pro Tools HDX & HD Native Systems (Mac) 6 07-10-2018 06:29 PM
Protools crashes when I try to bounce Josh523 Pro Tools 12 1 03-15-2018 07:02 PM
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 03:55 PM
Protools 11 with Waves crashing on offline bounce StefB Pro Tools 11 5 02-16-2015 08:35 AM
