Havin Problems with Buffer or WD Audio Drive? Here\'s my fix!
Are you having Buffer issues? Like "INCREASE BUFFER", then you do and PT is like, "DECREASE BUFFER"?
Here's my posts from the past couple days that will help walk you through some simple stuff to try- All but a couple of these things are Digi Recommended and were done per instruction from their web site. GOOD LUCK! I'll explaine in a second, first here's my Sandra: (Keep in mind, my Wireless Internet Adapter is set up right now just to get online -ussually off) If you're not familliar with this Sandra stuff, skip it- My trouble shooting process starts below it- seperated by ******* SiSoftware Sandra System Host Name : STUDIO User : Shorty Workgroup : MSHOME Processor Model : AMD Athlon(tm) 64 X2 Dual Core Processor 4200+ Speed : 2.20GHz Model Number : 4200 (estimated) Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Low Power, Dual-Core Internal Data Cache : 64kB, Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache : 512kB, ECC, Synchronous, Write-Back, 16-way set, 64 byte line size System System : MICRO-STAR INTERNATIONAL CO., LTD MS-7253 Platform Compliance : AMD LIVE! Mainboard : MICRO-STAR INTERNATIONAL CO., LTD MS-7253 Bus(es) : ISA AGP PCI PCIe USB FireWire/1394 Multi-Processor (MP) Support : 1 Processor(s) Multi-Processor Advanced PIC (APIC) : No System BIOS : Phoenix Technologies, LTD 6.00 PG Total Memory : 2GB DDR2-SDRAM Chipset 1 Model : VIA Technologies Inc K8M890CE Host Bridge Front Side Bus Speed : 2x 1000MHz (2000MHz data rate) Chipset 2 Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 1000MHz (2000MHz data rate) Total Memory : 2GB DDR2-SDRAM Memory Bus Speed : 2x 366MHz (732MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Adapter : RADEON X700 Series Adapter : RADEON X700 Series Secondary Physical Storage Devices Addonics CF (ATA) : 64MB WDC WD2500AAKS-00VYA0 (SCSI) : 233GB (C:) WDC WD4000AAKS-00TMA0 (SCSI) : 373GB (D:) IN-CDRW DX-CDRW (ATAPI) : N/A (E:) TSSTcorp CD/DVDW SH-S182M (ATAPI) : N/A (F:) Logical Storage Devices Win XP (C:) : 233GB (228GB, 98% Free Space) (NTFS) @ WDC WD2500AAKS-00VYA0 (SCSI) Audio Dive (D:) : 373GB (370GB, 99% Free Space) (NTFS) @ WDC WD4000AAKS-00TMA0 (SCSI) CD-ROM/DVD (E:) : N/A @ IN-CDRW DX-CDRW (ATAPI) CD-ROM/DVD (F:) : N/A @ TSSTcorp CD/DVDW SH-S182M (ATAPI) Peripherals Serial/Parallel Port(s) : 2 COM / 1 LPT USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA USB Enhanced Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : PS/2 Compatible Mouse Mouse : HID-compliant mouse Human Interface : USB Human Interface Device Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP (2002) Home 5.01.2600 (Service Pack 2) Platform Compliance : Win32 x86 Network Services Adapter : VIA Compatable Fast Ethernet Adapter Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. ************************************************** *********************************************** Are you having Buffer issues? Like "INCREASE BUFFER", then you do and PT is like, "DECREASE BUFFER"? Here's my posts from the past couple days that will help walk you through some simple stuff to try- All but a couple of these things are Digi Recommended and were done per instruction from their web site. GOOD LUCK! Ok..... I installed new Hard Drives, both System Drive and Audio, and freshly installed XP Home. Now I'm getting all those buffer errors again- increase buffer, decrease buffer, conflicting with CPU tasks..... yadda yadda yadda...... dang.......... The only stuff installed on my computer right now is PT LE 7.1, CD Architect 5.2(b), PT Factory Plugs, Free Bomb Fact Plugs, Nomad Plugs (3 Free), MME Helper, and a couple drivers (Wireless Internet USB Antenna, etc). I went through all the recommended stuff, like: Disabling a CF Card Reader I have in the computer (Soon to be replaced with a USB one) (Pro Tools was seeing this as a HD and jackin stuff up I think) Processor Scheduling: Background Memory Usage: System Cache Disabled unnecessary hardware (That I knew was safe, in Hardware Manager) Deleted DAE stuff, Preferences, Databases.... My Onboard Sound is DISABLED My onboard Shared VIDEO Memory is DISABLED I installed the Microsoft Dual Core Hotfix I installed the AMD Dual Core Optimizer (Of course these two things are hardware specific) In MSCONFIG, turned off all services that weren't Microsoft in MSCONFIG, turned off all startup except digi's MMErefresh & AMPdualcoreoptimizer I set the System Paging File for both drives to the System Specified option.... Cool n' Quiet: Disabled (Speed Stepping) Spread Spectrum is ENABLED in my BIOS (Not sure if that's related) My motherboard uses the SATA option to use RAID or IDE mode. I''m set to IDE. ************************************************** ************************************************ YAY!!!!! I GOT 'ER DUN!!!!! I'll explaine my fix here, and make a new thread related to Windows based LE buffer issues, and WD Audio Drive issues! Here's what fixed my issue. 1) I have an old IDE 'Addonics CF Card Reader' that showed up in 'Device Manager' under 'Removable Storage'.... I disabled it, but after a reboot at some unknown point, Windows removed the 'Removable Storage' catagory and placed it under "Disk Drives' and re-enabled it! I simply disabled it there, and as of yet it remains that way. I intend to remove it from my computer this weekend. 2) A good friend and IT tech (As well as a recreational artist/engineer) told me to disable 'Disk Indexing' on my Audio Drive (A brand new Western Digital 400GB SATAII 300Mbs 16 MB Cache). This was done by going to 'My Computer' and right clicking the Audio Drive choosing 'Properties', then deselecting the checkbox for 'Allow Indexing on this Drive for fast File Searching'. Done deal. I'm screamin. I now have my buffer setting at 64 and my DAE Pref at Default 2 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! During Playback my Usage Meter is around 1/8 capacity on the CPU, and my disk meter occasionally flutters a tiny incling of a sumthin....... SHE's SCREAMIN!!!!!!!!!!!!!!! HOPE THIS HELPS SOMEONE!
Shorty: Table Syrup Records Mac Pro 5,1 3.33 GHz Hex, 32GB EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23" OSX Sierra Pro Tools HD 11.2.2 Waves IOS, IOX, STG2412 Extreme Server (x2) Logic Pro X, DSP Quattro, Final Cut Pro X Waves Mercury+SSL+AbbeyRoads Trident S65 with embedded US-2400 Live: 2012 Mac Mini, Dual SSD, i7 2.4, 16GB Win 10, OSX Sierra LV1, MRSG Hardware from above (same gear) Dual Dell P2418HT Touch Screens Waves Icon X (x2), M, with Screens Custom enclosure |
i need help with a problem im havin with opening up protools | bm973 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 09-18-2008 05:21 PM |
Problems using same audio drive on OS and XP (Bootcamp) | syra | Pro Tools TDM Systems (Mac) | 3 | 09-01-2007 12:44 PM |
Audio clock problems with 64 h/w buffer | rogga_bogga | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-09-2007 10:56 AM |
PROBLEMS SETTING UP AUDIO DRIVE | JAEPILLA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 06-02-2004 06:14 PM |
H/W buffer problems on 1 drive only- an ANSWER | mommama | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-24-2004 06:50 AM |
