Does PT 8 support legacy interfaces?
I just installed PT8 on a rig with an Apogee ad-8000se interface attached to the legacy port on the 192i/0. it all works fine in PT7 but PT8 cant see the interface at all.
Have we really lost support for all these old interfaces? or is it a bug, or am i just missing something?? Thanks Sam |
Re: Does PT 8 support legacy interfaces?
I think it now requires that the legacy interface be turned on after PT is booted
or was it after the computer booted If you look around the PT8 compatibility doc you will find this info
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Thanks for the quick reply dude - i couldn't find any info in any documents and after about half an hour of searching i quit and tried both your theories. but no luck... can anyone explain exactly how to do this?
Cheers Sam |
Chris
Come on Sam, even I understood that reply. Better get Edd on the case, he'll know what to do Boot mac, power up AD8000, run tools or Boot mac, run tools, power up AD8000 or Tell the man he need to buy another 192! Speak soon no doubt S |
pffft. gimme a little credit steve! turns out my clock source was the 192 instead of the sync io. i dont know why but once i changed that the apogee appeared in my io setup. how are your pedals coming along? |
i cant get my ad8000se to play without a bunch of noise, its all distorted. how do you fix this?
I had that noise problem with my AD8000. It was a sync issue. As you are using the Sync I/O as the master clock check the front panel of the AD8000 and make sure your sync source is set to wordclock.
got it working, had to flip some of the dip switches on the digi cards
Anyone Using Legacy Interfaces W/ PT-9 TDM? | ProTooler | Pro Tools TDM Systems (Mac) | 10 | 08-30-2011 02:18 AM |
Where are my legacy interfaces in Pro Tools? | Detlef Brockmann | Pro Tools TDM Systems (Mac) | 1 | 06-28-2011 04:13 AM |
Legacy Interfaces running ? | audiocontrol | Pro Tools 9 | 13 | 02-01-2011 07:32 AM |
Poll: How many still using legacy interfaces? | Al้cio Costa | Pro Tools TDM Systems (Mac) | 124 | 10-30-2009 10:13 AM |
Does HD Exp Ch allow use of Legacy interfaces? | D Bag | Pro Tools TDM Systems (Mac) | 0 | 10-21-2006 06:25 PM |
