Creating the best mix levels / playback levels
Hi guys got a few questions about mixing levels and playback levels. I just recently started to record, and i was told that you have to keep the levels up close to the red but not IN the red. I have somewhat of a problem with that. When recording mic'd to a guitar cab, im pretty loud however the levels are going maybe 35%. When i yell into the mic for vocals, im gettin around 20% maybe. How can i increase this to get the loudest possible level without problems? Do I take care of all this in the master fader or? The reason why i ask is because i bounced to track a set of guitar riffs just to see how they were sounding, and i could barely hear anything at all. How should i go about increasing the levels?
Re: Creating the best mix levels / playback levels
Tracking near 0dbFS is very bad. You need to leave yourself some headroom for processing, and mixing. I track around -12dbFS myself.
Overall loudness is better left for the mastering stage. If you just want to bump the overall louness up for a quick mix test run a limiter on the mix bus. I wouldn't recommend mixing with a limiter on the mix bus though unless you're purposely trying to see how your mix decisions are affected by overall limiting. |
Ok i will try that. As far as the mastering stage, what would you recommend doing exactly?
You can attempt to do it yourself, but you'll likely spend a lot more time/money for less than satisfying results. |
HELP! Playback is not audible, although I am getting levels | pstlwhppd | Pro Tools 10 | 1 | 07-07-2013 06:13 PM |
Tracking Levels and Playback Levels | paul_g | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 11-26-2010 05:37 PM |
Low playback levels | HM Productions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-11-2008 11:25 AM |
Linking track levels w/ pre-fader bus levels? | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-07-2003 10:36 PM |
CD PLAYBACK LEVELS? | John W | Pro Tools TDM Systems (Mac) | 8 | 03-15-2000 05:27 AM |
