Re: Pro Tools V8 with SSL Delta Link MADI HD
I had a HUGE issue that was like finding a needle in a haystack in my system, and ended up being the DeltaLink.
I had to RE-install the firmware (same vrsion), and also unclock and re-clock. It's been fine since. It was absolutely brain-damaging before.
Mac Pro 3.7 GHz Quad-Core / Dual GPU 32 GB RAM PTHD 11.3.2 Mac OSX 10.10.5 UAD Apollo Quad UAD Satellite Octo PT 11.3.2 Macbook Pro 2.3 GHz Intel Core i7 Retina Mac OSX 10.10.5 16 GB RAM Presonus 24.4.2Ai UAD Apollo Quad |
What problems were you having before you did the above?
I was experiencing a very high spike at 15.7 kHz across all the audio tracks. You could see it on any channel if you put an analyzer on it. It presented like a very high modulation, a bit like rivets on some systemic cymbal. I mean really high! Made you grit your teeth, but it was hard to get a handle on what we were hearing.
I had just upgraded to a Mac Pro, and initially had a Magma chassis, so I wouldn't have to crossgrade to the PCIe cards. Initially I (and so did Magma) suspected the issue was with the chassis. But they changed it and no improvement. I even changed computers. I had to deconstruct my system and put it back together one component at a time till I narrowed it down. The weirdest thing is that the DeltaLink worked fine with the old system. Some weird interaction with the new computer! All is stable now.
We use it here with a Sys 5 and V8 no problem. If you have the older Euphonix hardware it will just not give you audio if you are sending a 64 channel madi stream into its 56 channel madi input. Sometimes we notice that the delta link had set itself to 64 channel mode which we have a problem with if using the 767 format converter. Try switching the modes in the delta link (using the A or B outs in the hardware setup I believe).
#16
I'm in discussions with SSL about this and they've not come across the problem before and are no real help tbh. |
#17
Give it a shot...
#18
Sorry to resurrect an old Topic Danny & everyone!
I am having a nightmare setting up my SSL madi with a new protools rig (magma chassis) and was wondering how you reinstalled the firmware without a PC? (I'm all mac here) Any help gratefully received. I am 64 channel, so my toggles are set AAAB (then all B) I've tried everything and no lock on the MADI. Nightmare! THanks Paul |
PT 8.0.5 on 10.5.8 Not locking to TC with SSL Delta-Link Madi HD | musiceditorcouk | Pro Tools TDM Systems (Mac) | 3 | 07-21-2011 09:37 AM |
HD MADI vs. SSL XLogic Delta Link | 1m1 | Pro Tools TDM Systems (Mac) | 1 | 10-11-2010 04:02 PM |
HD PCIe with SSL Delta link MADI HD Alpha link MADI AX | Juraj Bernáth | Pro Tools TDM Systems (Mac) | 3 | 09-10-2009 07:13 AM |
SSL Delta Link AKA Sydec Madi I/O | budster | Pro Tools TDM Systems (Mac) | 2 | 02-14-2007 08:28 AM |
Xlogic Delta Link Madi to HD? | Tim R. | Pro Tools TDM Systems (Mac) | 2 | 11-22-2006 11:05 PM |
