Old 03-25-2016, 03:35 AM
Mr.O Mr.O is offline
Default PT 12.4 Delay Compensation failure
In the studio, where I work, a Protools HDX 12.4 is installed.
Unfortunately the delay Compensation quite often fails, especially with use of UAD plug ins
Anybody has an idea, what the reason could be?
thanks
Mr.O
Old 03-25-2016, 04:05 AM
8dB.co.uk 8dB.co.uk is offline
Default Re: PT 12.4 Delay Compensation failure
Probably the old combining Avid DSP with "Native", which uad effectively is, to Pro Tools, on the same paths. PT has to do complicated routing when this combination arises.
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
Old 03-25-2016, 04:29 AM
yeah, could be - anybody has the same experience and what could help?
thanks
Mr.O
Old 03-25-2016, 04:32 AM
Have tried moving them off the same path?
Old 03-25-2016, 06:25 AM
cut cut is offline
One old school rule that still applies is keep the Native ones on the top - don't intermix native and DSP. I always use "Native North" as a reminder to keep them grouped above the DSP. I have HDX and just did a film mix with great results - including no problems with delay compensation.
Old 04-03-2016, 07:58 AM
Carl Lie Carl Lie is offline
Helpful thread. I do find it with UAD instances but was also messing with HDX as inserts.
Will try this. thanks
Carl
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Automation Delay With Delay Compensation On? hbadger30 Pro Tools 12 1 02-10-2016 01:07 PM
help fixing plugin delay and delay compensation disaster prestonhavill macOS 14 12-24-2014 03:35 PM
Delay compensation with backline delay chuck goodwin VENUE Live Sound Systems 3 08-09-2013 07:54 AM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 11:10 AM
Delay compensation- choice of 'Medium delay'? dtmprod Pro Tools TDM Systems (Mac) 2 05-05-2010 11:00 PM
