#81
Re: PCIe SSD cards and Mac Pro upgrades
It can be done that way, but it's a lot more complicated when you do it that way. There's always a risk of applying to much pressure to the CPUs when you go that route, plus everything has to be tightened down perfectly, there's just a bunch of problems that could be had by going that route. Deliding the CPUs makes it a piece of cake for install and all of those potential pitfalls become irrelevant.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
#82
Yes I’ve seen that, but I have a friend that used an iron on two sets of CPU:s with success, so I think I’m gonna try that method, if you don’t have any other advice.
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60 macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4 |
#83
Anybody using the following?:
8x 16GB (128GB) Micron DDR3 ECC RAM Mac Pro 4,1 5,1 1333 Mhz PC3-10600R Those are less expensive than the Samsungs right now, and are supposedly the same quality. Good choice?
#84
Sent from my SM-G935V using Tapatalk |
#85
Thanks for all help and advice so far!
I’m now shopping for parts. Are all CPUs like the following compatible with cMP 4,1 / 5,1, or are there any incompatible models?; 2x Intel Xeon X5680 12M Cache, 3.33 GHz, 6.40 GT/s 2x Intel Xeon X5690 12M Cache, 3.46 GHz, 6.40 GT/s
#86
With two HyperX Predator drives; one 480GB and one 960GB, how would you distribute work load?
1. Use the 960GB for sample streaming only, the 480GB for OS/boot only, and another SATA/SSD drive for Pro Tools projects. 2. Partition the 960GB; eg 800 for sample streaming and 160 for Pro Tools projects, the 480GB for OS/boot. 3. Use the 960GB for sample streaming only, partition the 480GB; eg 300 for OS/boot and 180GB for Pro Tools projects.
#87
There is absolutely no point in partitioning SSD, it may even be counter-productive to do so. Just use it for two purposes if you want to.
#88
If you're streaming samples then a RAID 0 array is absolutely the way to go.
Dave Marsden UK |
#89
Even with a M.2 1350MB/s?
#90
Maybe not but that's a theoretical maximum. Does your Mac's PCIe bus support that much throughput?
I was referring to the likes of a Samsung EVO or in my case fast Crucial SSDs. Sample streaming is considerably smoother and puts less strain on the CPU in the case of Kontakt. You get a lot fewer -9171 errors.
Dave Marsden UK |
Accel Cards next to other PCIe Audio Cards in the same Mac Pro for PT 10+11? | relaxo | Pro Tools 11 | 12 | 05-14-2020 02:05 AM |
HD 3 Core PCIe and 2 Accel Pcie cards | JonGon | Buy & Sell | 0 | 04-05-2015 09:02 PM |
Are all pcie cord cards, accel cards? | fourthtunz | Pro Tools TDM Systems (Mac) | 2 | 11-20-2011 08:41 AM |
PCIe cards not being recognized in my MAC PRO ProTools not launching with cards in | phatbeatstudio | Pro Tools TDM Systems (Mac) | 6 | 10-15-2011 11:35 PM |
Mix up PT HD PCI and PCIe cards? | Matiz | Pro Tools TDM Systems (Win) | 0 | 03-01-2006 01:25 PM |
