Black and White Image flowing from a Canopus ADVC100
My Pro-Tools HD 4 out of the blue, started sending black and white image (instead of color .movs out the canopus box today. I tried trashing the pro-tools preferences, and the DAE preferences etc, but it still does it.
Before I go off on some long troubleshooting tangent tomorrow, I thought I would post and ask if anyone has ever had these issue and thus some obvious solution. For what its worth, if I play the movie to the screen instead of the 'out the firewire port' option it still plays in color. It just refuses to send color images out the firewire! Weird eh? Yours in music Ciaran |
Re: Black and White Image flowing from a Canopus ADVC100
Well, I tested one more layer, and narrowed down the problem so this posting is now mute....
Its definitely not pro-tools, because streaming from Imovie on a different computer through the Canopus results in... you guessed it.... black and white image... So now I just have to figure out if its the TV input, the capous box or the cable! Thanx |
one bit of free information as i see this all the time : the word for an issue that is now obsolete is 'MOOT' not 'MUTE'
do as DX suggests. if the cable swaps don't work, try re-installing Quicktime. many people have had issues resolved by doing this. the Cannabis (ha!) is using QT anyway.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Its called a "Can O' Puss" down here.
I have the B&W issue with my VVTR, and found out I had a bent pin on the S-video cable connector. The cable carries B&W on one wire, and the color on the other.
IMDB |
Make sure your PAL/NTSC switch on the Canopus matches picture
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Is one of those wire .1% longer? i believe you have a good diagnosis, i am sorry if i gave the impression that i thought it wasn't. the B&W thing does seem to point that and a QT re-install was for NO picture. but, i thought it might help.... it could be the FW device, it could be the TV. or, as a last resort, give up on mix to picture stuff and switch to music because it is so much easier. -covers head as he scurries out door...
Can I use Canopus advc100 Box With PT8 | JamesPondAqu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-26-2010 06:54 AM |
Canopus ADVC100 - Mac OS X | Alagu | Pro Tools TDM Systems (Mac) | 7 | 03-05-2004 10:03 PM |
canopus ADVC100 + FW drives?? HELP | esparza audio | Post - Surround - Video | 2 | 03-21-2003 06:40 AM |
Canopus ADVC100 and new macs | blanos112 | Pro Tools TDM Systems (Mac) | 0 | 10-18-2002 02:49 AM |
Canopus ADVC100 Out Of Sync | blanos112 | Pro Tools TDM Systems (Mac) | 2 | 08-23-2002 10:35 AM |
