Old 05-10-2005, 09:24 PM
Ciaran Ciaran is offline
Default Plug-in Alternatives to Dolby CAT 43 noise reducer
Hi I was just wondering what the favorite Noise reduction plugins were as alternatives to the standard Dolby CAT 43 Film Processor?
How does everyone rate the DINR, or Sonic NoNoise, Waves X-Noise, or Soundsoap ?
C.
Old 05-11-2005, 01:30 PM
GTveito GTveito is offline
Default Re: Plug-in Alternatives to Dolby CAT 43 noise reducer
I am using Waves C4 as a CAT 43 "emulator". It's not as efficient or brutal, but used properly it's quite good. The C4 has totally replaced the SR version CAT 430. On my last films I'll only used the CAT 43 on maybe 4 or 5 lines. After using C4 I'll also use less no-noise type plugs. They tend to add to many artefacts. A fast solution on a more single band noise, is to modify the "hiss remove" preset (?? not in the studio, so it might not be the correct name) in Waves audio-track.
Gisle Tveito
www.norskfilmstudio.no
Old 05-11-2005, 01:58 PM
FlorianE FlorianE is offline
C4 is really the most CAT43-like.
DINR sounds more like a funny music instrument.
NoNoise is another story. Except that as TDM it has a latency of some 4000 Samples (!, nice if you work to picture..) and is not comfortable to use. I sort of keep it up my sleeve for really desperate cases, where it has indeed occasionally worked wonders. But you have to go audiosuite, take a noise print, save that, go back TDM, apply noiseprint, bounce to new file, etc. Perfect for when you've got nothing left to loose.
Cheers
Florian
Old 05-11-2005, 02:42 PM
minister's Avatar
minister minister is offline
the wavearts multidynamics plug is very similar to C4. though cheaper... HOWEVER, it is RTAS only at the moment.
wavearts
the pirate hipped me to it.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 05-12-2005, 09:28 AM
Some interesting feedback on these plugins. And thanks minsister for the tip on wavearts - I'm off to try and download a demo from the site and look into the C4 that everyone seems to be using as well.
Ciaran
www.ciaranhope.com
Old 05-12-2005, 12:53 PM
Pirate Post Pirate Post is offline
wavearts
The 6 bands on the WaveArts vs the 4 on the Waves C4 can sometimes pull off miracles. The WaveArts lets you hone in on problem areas better and you don't have to deal with WUP! (but that's another story...)
Peter Cole - Head Pirate
http://www.beforenoonpost.com
http://www.piratepost.net
Old 05-12-2005, 05:39 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
He said WUP!!!!
IMDB
Old 05-12-2005, 10:28 PM
Hi Pirate,
I'm starting my 30 day trial of the Wavearts bundle and toying with the bands and functionality. I was particulary interested in this plugin as my alternative to the CAT 43 as there are several scenes that have way way to much wind noise on mics and I have to solve it this Sunday to be exact Have you any suggestions using either the C4 or the Wavearts?
yours
Ciaran
Old 05-13-2005, 08:52 AM
bigbadhenchman bigbadhenchman is offline
yours
Ciaran
ADR
M-Powered Forum
www.markhensley.tv
Old 05-13-2005, 09:41 AM
filmixer filmixer is offline
>ADR<
Henchman, you should know by now the obvious is never the answer in this forum.
Mark Ettel C.A.S.
HTML code is On
Dolby Noise Reduction Units TNagle Post - Surround - Video 11 12-07-2005 03:42 PM
Dolby makes Big Noise dr sound Post - Surround - Video 1 02-18-2005 09:53 AM
Alternatives to Sound Replacer plug-in??? WATYF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-03-2004 01:42 PM
bit rate reducer distortion vst plugin aishabag23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-12-2004 11:47 AM
Noise Reducer in Pro Tools LE???? Digi_Shawn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-27-2004 07:11 PM
