Old 05-05-2005, 11:13 AM
EyelashoutEnt EyelashoutEnt is offline
Default how to drop markers
Anyone know the quick key to drop a marker? I'm separating regions from a VO session and I need to run through and mark all the good takes.
What's the fastest way to drop markers?
Old 05-05-2005, 11:46 AM
Strider Strider is offline
Default Re: how to drop markers
Hit the enter key (on the numeric pad), it will prompt you for the parameters you want in your marker, then hit enter again. Go to WINDOWS and open the markers window to see them in a list. You can also recall them by hitting the period key (also on the numeric pad), the number of the marker, then period again. Option click will delete them, or drag them down into the timeline from the markers view to delete them.
Mark Keefer, M.P.S.E.
http://miscellaneouscreativity.blogspot.com/
Old 05-05-2005, 12:42 PM
suh wheat. now i remember. gracias.
Old 05-06-2005, 12:23 PM
Ciaran Ciaran is offline
I don't suppose you know how to renumber markers, to tidy up the numbering? Or, do we just have to deal with weird orders depending on where we drop the next one!
Ciaran
www.ciaranhope.com
Old 05-09-2005, 08:41 AM
tj_davies tj_davies is offline
I've been asking Digidesign for a renumbering option, but so far, you'll have to do it by hand! I thought I was the only one interested in this option. Nice to hear there are others, too!
By the way, if you already know the number, that the marker should get: Hit period (numeric pad)+marker number+enter (numeric pad).
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 05-12-2005, 10:08 AM
Thank you for that tip! I am going to try and use it today ! Yeah, the marker functionality is rather limited for such a powerful aid to mixing. I use them to mark pivot point in underscore when I am scoring, and to mark everything from CUTs to things that need fixing. It is insane when I want to move them or place new ones in and they don't automatically renumber based on their order!!
Ciaran
www.ciaranhope.com
Old 05-12-2005, 10:26 AM
On the Num Pad... PERIOD + {NUMBER} + ENTER
That will assign the Marker to memory location NUMBER.
Workaround:
You could also export a dummy MIDI track to a Standard MIDI File then delete all markers and import the Standard MIDI File and the markers will be renumbered by location.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
HTML code is On
Beat Markers Appearing As Elastic Audio Markers Fabdickson Pro Tools 9 1 03-06-2012 05:03 PM
How to turn all Event Markers into Warp Markers ??? fman Pro Tools TDM Systems (Mac) 15 04-29-2011 01:46 PM
Can't drop markers with Enter key! Mikhail 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-06-2010 02:51 PM
pulldown and drop/non drop problems ilinx Post - Surround - Video 2 05-16-2008 09:46 AM
Lining up Drop Frame to Non Drop Roger Stauss Post - Surround - Video 4 10-10-2007 06:36 AM
