TL SPACE behaving unusually
I don't know if anyone else is using TL Space for creating room environments or not, but here goes. I was stumped as to why I could not coax a signal into the stereo input for TLSpace hard left or right. If I would do it, it appeared to make no real difference to where it came out in the 5.0 output. Finally, after much experimentation, here are they symptoms. The TLSPACE L,C,R,Ls,Rs path order on the readout seems to conflict with the L,R,Ls,Rs,C Pro-Control order. No matter what way I re-organize path order on its output bus, it insists on sending the signals to the wrong place. The test... - If I hard pan an I/P to the left the resultant signal appears on the L R and Rs channels If I hard pan an I/P to the right, the resultant signal appears out the C and Ls channels Even if I create an elaborate bus system to fix the LCRLsRs to LRLsRsC behavior, it still doesn't explain why right panning the I/P has 2 resultant channel outs and the left I/P has 3. Incidentally, Revibe has the same LCRLsRs path order and behaves beautifully. Ciaran www.ciaranhope.com |
major surround issue with TL SPACE in ProTools 6.9
I am posting this info regarding weird behavior I am having with TL Space in my pro-tools sessions.* Digidesign have been kind enough to sit on the phone with me and verify the TL SPACE erroneous behavior on one of their pro-tools rigs, so now it is an official problem with the plugin as opposed to simply being a bug in my own studio.* I don't know if it is something you guys have noticed, but I will try and lay out the behavior as clearly as I can.
The plugins behavior became a serious issue when I was mixing a 5.1 film score and trying to use a surround instance of TL SPACE as a 'room emulator' for the orchestra.* I created a stereo auxiliary channel and put TLSpace on it.* I used TL SPACE long, with the stereo-5.0 configuration (we've since verified that the problem exists for the Medium and Short options as well). The Channel I/P was set to a stereo bus(to feed the mono individual instruments to at different pan locations), and I made a 5.0 TL Space Bus for the O/P. Here is what happens next.
What bothers me more though, it that ultimately, the error is appearing before the signal even gets to an o/p bus, in the sense that the monitor window of the TLSpace shows the same wrong channeling no matter what the o/p is doing. So, even if I create an elaborate bus system to fix the LCRLsRs to LRLsRsC behavior, it still doesn't explain why right panning the I/P feeds 2 resultant channel o/ps and panning the i/p left feeds 3. It is basically impossible to use the TL SPACE plugin as* a surround reverb plugin with the room emulation as screwed up as this.* Nothing can be localized in the room, and the emulation is a misrepresentation of the IRs to boot. I don't know what you might know about these issues, but any feedback on it at all would be fantastic. Yours in music Ciaran Hope [email protected] www.ciaranhope.com |
Fades behaving badly. | costa | macOS | 8 | 07-15-2011 11:29 PM |
Q6600 Dverb Test Unusually Low | jmorganmitchell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 35 | 03-12-2010 11:30 AM |
ProjectMix not behaving correctly with OS X 10.4.9... | indiecodemonkey | Pro Tools M-Powered (Mac) | 9 | 10-03-2007 02:54 AM |
Strike Not Behaving | digijohn | Virtual Instruments | 5 | 05-03-2007 11:39 PM |
how is your 9.1 behaving ? | TRIRATS | Pro Tools TDM Systems (Mac) | 1 | 05-03-2001 02:20 PM |
