Low latency monitoring 11.3.2
Hi guys,
I am using PT HD native 11.3.2 on OSX 10.8.5 and want to use Low Latency Monitoring again but this isnīt working anymore I already checked the manual and the I/O setup to engage the button and select the output - no way! Itīs ridiculous: At any update bugs are fixed, other bugs are introduced - and that should be the industry standard DAW? By the way: The Midi bug with the sustain pedal isnīt fixed yet - we are telling them for years now - nothing happens. a really unhappy Mr.O |
Re: Low latency monitoring 11.3.2
i have not had an HD system since HD 8 so if i am incorrect .. someone will come along with HD native to correct me .. so just record i believe this is correct though ... cheers john
No he is right there is a LLM monitoring path for the native systems.
I am just not sure what he believes is the problem
the problem is, you canīt hear anything you can see, the track is recording, see the waveform, but at the output selected in the I(O setup there is no signal this means, the low latency output is correctly routed to the selected output, but this connection in obviously broken Or am I overseeing something? hey Mr.O |
Let me try this,
pretty sure works normally but I am at 12.2.1
I don't know if that's the work around or not but it works for me like that.... but yes with LLM engaged and direct out to the LLM path....you are not able to monitor the signal.
Just a comment from my experience - HD Native, TB box, Omni. If I select the LLM menu option the headphone output of the Thunderbolt box does not pass audio for the tracks in record. However, the headphone output of the Omni does correctly go into LLM.
I don't own an omni, yet..... If it's easier for Avid to mail me a free one than to fix it so it works with my HDi/o.... Well let's just say I understand
Low Latency Monitoring | Mr.O | Pro Tools HDX & HD Native Systems (Mac) | 0 | 02-11-2012 11:26 AM |
9.0.3 Low Latency Monitoring | 440Hz | macOS | 3 | 07-21-2011 07:19 PM |
lowest latency without "low latency monitoring" ? | music project | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-11-2010 08:40 AM |
Latency Monitoring | sweetbabysims | Virtual Instruments | 1 | 11-21-2007 01:22 PM |
monitoring latency | zimm | Digidesign Hardware & Software | 0 | 03-02-2001 12:48 AM |
