Share Your Quickeys Pro Tools Shortcuts Here!
I know some have mentioned using Quickeys with Pro Tools ,and thought it might be a helpful thread up here if those who did, shared some of their favorite timesavers in a thread we could all copy.
I know I'm going to make a one key equivalent right off the bat that switches from INPUT to AUTO INPUT....I can't believe Digi put that switch on the Control 24 so far away from the transport! |
Re: Share Your Quickeys Pro Tools Shortcuts Here!
command+option+shift+B "Bounce To Disk"
command+option+shift+N "Delete Selected Track(s)" command+option+shift+F "Delete Fades" command+option+shift+U "Show System Usage" command+option+shift+P A sequence that toggles between "No Auto-Scrolling" and "Page Scroll During Playback" command+option+shift+S calls up the "SoundReplacer AS" plugin command+option+shift+V calls up the "VocAlign AS" plugin command+option+shift+D calls up the "Duplicate AS" plugin command+option+shift+C "Save Session Copy..." command+shift+S "Save Session As..." command+; "Preferences" I also use the ` key which triggers a sequence to toggle between Slip and Grid modes. This makes drum editing very fast. I wish there was a way to add a key-command for "Delete Unused Regions Except Whole Files." It's location is in a non-standard Finder menu. And, I also wish there was a key-command to toggle between the Trimmer tool and it's TC/E equivalent. |
Thanks S2N...good ones....
Keep 'em coming...especially any cool sequences anyone has worked out.. |
How do you create a quickkey for menu items in sub folders?
Is it possible to assign the "S" key to the Solo command?
Is is possible to assign the Up and Down arrows to a command that selects tracks in the mix window either up or down? |
One I use all the time is...
'Control-Option-Command-T' for putting the numeric keypad into transport mode. and 'Control-Option-Command-C' for putting the numeric keypad into classic mode. I have a system of saving zoom commands, etc. into certain numbered slots. sm
macmandigital.com |
Command+option+C=compact selected
Command+option+B=bounce to disk Command+option+M=clear movie selection Command+option+I=import tracks Command+option+U=peripherals Command+option+P=preferences Nick
[email protected] Newcomer Audio Post MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... |
cool...
is it all written in manual? why are people asking digi to make a bounce-to-disk shortcut in NEXT version of pt? |
cebola,
cuz this has nothing to with protools software.. its a 3rd party app Quickkeys... MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
Video of My Custom PT Quickeys Key Command Shortcuts | relaxo | Pro Tools 10 | 9 | 02-04-2013 04:24 AM |
disable triggering Quickeys Shortcuts when typing in text... | clusterer | Pro Tools TDM Systems (Mac) | 2 | 02-16-2010 04:27 AM |
- QuickKeys Q's - & Share your QK Shortcuts - | KingFish | Tips & Tricks | 7 | 10-23-2009 05:36 AM |
PT 6.7, KB Shortcuts, QuicKeys [Heads Up] | Andre Knecht | Pro Tools TDM Systems (Mac) | 2 | 11-02-2004 03:25 PM |
What Quickeys shortcuts do You use? | Tim R. | Tips & Tricks | 2 | 12-08-2000 11:20 PM |
