Tempo Mapping issue with bars and meter
Dear Community,
I'm having an issue after creating a complex tempo map with identify beat: While done doing the tempo map, I noticed a meter change I missed. So I try changing only bar 7 from 4/4 to 3/4 without changing anything else from Bar 8 on. Any way I try doing this changes following bars: even tho tempo markers do stay at their position, bars move... I just want bar 7 changing the meter to 3/4 without affecting it's absolute length or moving anything afterwards. Any ideas how to do this? Thanks in advance, J Last edited by The_Juan; 11-11-2021 at 09:08 AM. |
Re: Tempo Mapping issue with bars and meter
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
render a blank piece of audio to a track called tempo map.
make cuts on all the tempo and meter events, so that they're locked in position and you have unmoveable reference points. copy your tempo and meter timeline section into the copy buffer (both tempo & meter timelines selected) make your change to the meter at the desired position delete all tempo and meter events after it paste your copied tempo and meter buffer at the desired following position of your saved cut (both timelines selected) does that work? |
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Yeah, that's a wild answer by Tweakhead!
I'm having trouble understanding the problem. Your "ID beat" tempo map read bar 7 as 4/4 but it's really 3/4? And is everything from bar 8 on displaced by 1 beat - like beat 4 of bar 7 is actually beat 1 of bar 8? All I know is that if you change the meter on one bar you need to change back on the following bar or it stays in the new meter. So "meter+ bar 7=3/4", followed by, "meter+ bar 8=4/4". But I'm sure you know that and it's not the situation. Do you need to change it to match a score or something? Just curious. |
good point by JJ.
I had assumed that since it was already at 4/4 there would be a 4/4 event automatically inserted when the copy-buffered timelines were finally pasted - but to assure this happens it might be good to first add a 4/4 meter event at the start of the selected area to be copied - so that it definitely gets inserted after the newly-changed 3/4 bar. |
How to set bars/Grid to MATCH the tempo/metronome? | digirocker | Getting Started | 1 | 03-09-2021 11:44 AM |
tempo mapping and meter edits problem | mickblah | macOS | 5 | 02-23-2017 04:39 AM |
Renumber Bars = Meter Change bug? | Dizzi45Z | Pro Tools TDM Systems (Mac) | 0 | 02-18-2011 03:06 PM |
Midi, tempo, bars and beats | LincolnT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-13-2009 11:41 PM |
Changing Tempo - Negative Bars?? | JayCRB | MIDI | 0 | 08-10-2006 09:35 PM |
