Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 08-16-2018, 11:53 AM
macmusic9 macmusic9 is offline
Default "NEW" MacBook Pro 2012 Which OS should I go with?
I bought a great shape 2012 MacBook Pro unibody ( so it has all the ports, thanks Apple ) and it came with Sierra. It's the quad I7 2.3, 16 gig ram, 500 gig SSD ( not fusion ). My PT 12 caps out at Yosemite unless I upgrade, my Waves plugs are good from there to High Sierra, komplete 11 is good from there also.
Before I start to load things in, was wanting to get some opinions from fellow DUC's. Should I revert back to Yosemite, stay at Sierra, or upgrade to High Sierra? If I stay or upgrade, then I have to upgrade PT but the rest is good.
Just so you know, I've been rocking a HD 3 system on PT HD 8 forever and see no reason to stop using it for tracking and mixing ( loaded for bear with software and plugs for this system ). Didn't upgrade HD but did upgrade 2 regular PT licenses with support and they capped out at 12 under Yosemite. I have never used those even though I did install on another drive. I have considered the HD upgrade that way I can have HD 10 for my old system and 2018 for the MacBook. Or just upgrade a regular license to 2018 for the MacBook.
So, which OS have you had the most success with, which seems more stable? Any input would be appreciated. Thanks!
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
Mac i5 2012 "Bus Error" in thread "Main Thread", at address 0x0 tony20970 macOS 2 01-29-2014 10:45 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
"Mid 2012" Mac Pro 12 core - working OK with TDM Accel? HDX? MixerGuy macOS 1 07-11-2012 05:10 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
