Old 09-04-2009, 10:29 AM
darbyclash34 darbyclash34 is offline
Default New Unibody Mac Questions
So a stereo fell onto my MacBook Pro from 2007, killing it totally. So I went and got a new MacBook Pro Unibody. I use an 002R and an external FW800 harddrive. I had been hooking them up with 002R running into the FW400 port and the Harddrive on the FW800 port. Now I only have one FW800 port. What is considered the best way to hook this up? Should I switch to USB for the HD?
Old 09-04-2009, 11:11 AM
getz76 getz76 is offline
Default Re: New Unibody Mac Questions
Macbook Pro FW800 -> FW800 Drive -> 002R
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 09-04-2009, 12:02 PM
@ndy's Avatar
@ndy @ndy is offline
Never use USB for hard drives with Pro tools. Error city!
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4
Old 09-04-2009, 12:12 PM
docbop docbop is offline
The Mac->FW800 drive->002r will work most of the time, but it is not the Digi blessed way. I have had a system like that worked for years and then one day start throwing errors and would stop till I switched all FW400 config. To be safe you may want to have a FW800->FW400 cable or adapter around. Digi only supports an all FW400 setup.
Steve B.
If you think you can or if you think you can't, you're right.
Old 09-04-2009, 12:59 PM
So you're saying to convert to FW400 before hitting the hard drive? So it would FW800 (computer) to FW400 (hard drive) then FW400 to the 002r?
Old 09-04-2009, 01:07 PM
@ndy's Avatar
That is the safest way. Firewire 800 to 400 cables are inexpensive and work great. Good luck.
Old 09-04-2009, 01:17 PM
Oh yeah, I've got the cables around so thats no problem. Cool, I'm doing my first session with it tonight (client was there for the old computer's destruction so he knows we're on shaky new ground here) so thanks for all the help!
Old 09-04-2009, 02:11 PM
This is what I wanted to agree to.
Yup.. That's it. +1
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 09-04-2009, 02:14 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
if you have the availability to, on the pro, use an express card with firewire. no problems here!
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 09-04-2009, 02:18 PM
Unfortunately, the new Pro's don't have an expresscard slot they have an SD card reader, which bothers me. I miss the expandability options. Thanks again for the help!
Best pre Unibody MBP for Pro Tools soundboy35 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 31 10-14-2010 07:56 PM
HELP: PT LE 8 on Macbook (unibody)... AKGambino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-23-2009 07:49 AM
Your 003 Unibody MBP configuration ergalthema 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-22-2009 06:05 PM
PT LE 8 on Unibody MacBook for a week... FreqSabotage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-14-2009 09:24 AM
Unibody 17" Macbook Pro ? plutone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-28-2009 12:52 PM
