using P.T 7.3, reason is not showing up as a plug-in???
I am running Reason 3, and it is not showing up as a plug-in under the Instrument insert in Pro tools. Is this becasue i need a higher version of Reason to access it as a rewire option because i am now running a higher version of Pro Tools?
any help would b greatly appreciated thanks. |
Re: using P.T 7.3, reason is not showing up as a plug-in???
Yeah I just found out Reason Adapted 2.5 isn't showing up in mine last night. I haven't used reason much since getting strike, syncronic, xpand, and hybrid. Anyways I opened up an older session that did have reason in it, but I got the Plug in not found. But it is in the plug in folder. Is this a 7.3 issue? It's not critical that I have it but I would like to use it if I need to.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
Reason 3.0 or higher is required for compatibility with Pro Tools 7 or higher. If you have Reason Adapted 2.5 from the original Ignition Pack or Bundlemania your only option is to purchase the upgrade to the full version of Reason.
If you're on an Intel Mac, you'll need Reason version 3.0.5 - is this possibly your situation, Tomward? If it's not, you may want to reinstall Reason or dowload the separate ReWire component from the Propellerheads website, as it may have become corrupted. |
That's what I needed to know. Guess I'll look into upgrading.
Reason Not showing Up Under Plug Ins | steadward | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-21-2011 04:33 PM |
Reason Not Showing Up as Plug | brokenandallen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-31-2009 08:34 AM |
Reason 3.05 not showing up in plug-in folder | illyaas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-24-2007 12:31 PM |
using P.T 7.3, reason is not showing up as a plug-in??? | tomward | Pro Tools M-Powered (Mac) | 0 | 03-13-2007 06:45 AM |
Reason plug-in not showing up?? weird.... | dougied | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-12-2007 08:13 AM |
