Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 08-26-2020, 11:13 AM
Golden Case Golden Case is offline
Default Some inputs or outputs may have become inactive because your audio hardware device ha
Hi there,
I have recently installed PT first on WIN 10 Desktop and am using UA Apollo Twin USB for DAW
I can not get the I/O to work and get the error message - Some inputs or outputs may have become inactive because your audio hardware device has changed. - although I have not even been able to record a track yet
Please help
Thank you GG
Old 08-26-2020, 11:54 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Some inputs or outputs may have become inactive because your audio hardware devic
Hello and welcome to the forum.
Please take a look at the Help Us Help You thread where you will find general setup, optimization and troubleshooting tips for Pro Tools.
Not having much detail about your system, the first thing I would try is to make sure Windows is not using the Apollo as it's default sound device. You should go into Windows sound properties and disable all Apollo inputs and outputs so that Windows does not use them for sound. After doing this, reboot your PC, then run PTF and see if you get any further. You may have to open the Playback Engine and reselect the Apollo in PTF.
If that doesn't work, post a few more details about your system and we will be in a better place to help you.
Thanks,
Will
Will
System Details
Old 08-26-2020, 01:36 PM
Thank you for your quick reply
I did as instructed but unsuccessful - here are more details
I am trying to install PT 1st on my computer - I have not been successful so far as I keep running into an inability to setup I/O.
Even when I select the setup drop down the I/O option is not there
I am using the UA Apollo twin for my DAW and I can hear playback of tracks that are opened from templates - But that is all
I hope this helps - I really appreciate your help
SiSoftware Sandra
ID
Host Name : DESKTOP-QK6AQGL
Workgroup : WORKGROUP
Computer
Model : GigaByte Gaming B8 Default string
Serial Number : Default*******
Chassis : Default string Desktop
Mainboard : GigaByte Gaming B8-CF
BIOS : AMI (OEM) F7 07/06/2017
Intel vPro : 11.6.27.3264
Total Memory : 12GB DIMM DDR4
Processors
Processor : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz (4C 8T 4GHz, 3.4GHz IMC, 4x 256kB L2, 8MB L3)
Socket/Slot : FC LGA1151
Chipset
Memory Controller : Gigabyte Core6D (Skylake-D QC) Host Bridge/DRAM Registers 100MHz, 12GB DIMM DDR4 2.13GHz 64-bit
Memory Module(s)
Memory Module : Samsung M378A1K43CB2-CRC 8GB DDR4 1Rx8 PC4-19200U DDR4-2400 (17-17-17-40 4-57-19-6)
Memory Module : Hynix (Hyundai) HMA851U6AFR6N-UH 4GB DDR4 1Rx4 PC4-19200U DDR4-2400 (17-17-17-40 7-57-19-6)
Video System
Monitor/Panel : Hewlett Packard HP 27bw
(1920x1080, 27.2")
Video Adapter : NVIDIA GeForce GTX 960 (1024S 8C SM6.4 1.18GHz/1.24GHz, 2GB 7GHz, PCIe 3.0 x16)
Graphics Processor
OpenCL : NVIDIA GeForce GTX 960 (1024S 8C 1.18GHz/1.24GHz, 2GB 7GHz)
D3D 11 : NVIDIA GeForce GTX 960 (1024S 8C 1.18GHz/1.24GHz, 2GB 7GHz)
OpenGL : GeForce GTX 960/PCIe/SSE2 (2GB)
Storage Devices
Disk : WDC WD10EZEX-08WN4A0 (1TB, SATA600, 3.5", 7200rpm)
Disk : Samsung SSD 860 EVO 1TB (1TB, SATA600, 2.5", SSD, OPAL)
Logical Storage Devices
Windows7_OS (D:) : 919GB (NTFS, 4kB) @ WDC WD10EZEX-08WN4A0 (1TB, SATA600, 3.5", 7200rpm)
Hard Disk : 874MB (NTFS, 4kB) @ WDC WD10EZEX-08WN4A0 (1TB, SATA600, 3.5", 7200rpm)
Lenovo_Recovery (E:) : 12GB (NTFS, 4kB) @ WDC WD10EZEX-08WN4A0 (1TB, SATA600, 3.5", 7200rpm)
SAMSUNG V-NAND SSD 860 EVO (C:) : 931GB (NTFS, 4kB) @ Samsung SSD 860 EVO 1TB (1TB, SATA600, 2.5", SSD, OPAL)
SYSTEM_DRV : 96MB (FAT32, 1kB) @ WDC WD10EZEX-08WN4A0 (1TB, SATA600, 3.5", 7200rpm)
Peripherals
LPC Hub Controller #1 : Gigabyte B250 (Union Point) PCH LPC Controller
LPC Legacy Controller #1 : T2 86-86
Audio Device : Gigabyte ICH200 (Union Point) HD Audio
Audio Codec : Realtek Semi 1220
Audio Codec : 32768 0000
Audio Device : ZOTAC International (MCO) GM206 High Definition Audio Controller
Audio Codec : nVidia 0072
Disk Controller : Gigabyte ICH200 (Union Point) SATA controller [AHCI mode]
Disk Controller : Gigabyte ICH200 (Union Point) PMC
USB Controller #1 : Gigabyte ICH200 (Union Point) USB 3.0 xHCI Controller
USB Controller #2 : Gigabyte ASM2142 USB 3.1 Host Controller
SMBus/i2c Controller #1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft Print To PDF (600x600, Colour)
Biometrics
Voice : Analog NUI Voice Virtual Sensor (Voice)
Network Services
Network Adapter : Intel(R) Ethernet Connection (2) I219-V (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 10 Professional 10.0.19041
Platform Compliance : x64
Performance Enhancing Tips
Warning 2513 : TPM not detected. Some security features are unavailable.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Cheers - GG
Protools first 2019.6
Windows 10 Pro
Intel Core i7-6700 @ 3.40GHz
12.0 GB RAM
64 bit OS, x64-based processor
Audio Interface UA Apollo twin Mark II Duo core
Old 08-26-2020, 03:27 PM
Here are a few things to check:
#1-hold the N key while opening Pro Tools. This will take you to the hardware setup page where you select the device(the Apollo) that will act as the "audio engine"
#2-Once you verify that the Apollo is selected, go to Setup>IO and hit the Default button on both the Input and Output tabs(this may not be needed, but its also worth trying).
#3-open Settings>Sound and make sure that the Default Playback Device is the on-board sound card(Realtek?). You don't need to disable the Apollo, you just need to make sure that Windows is not going to use it(so Pro Tools has complete control of your interface).
#4-Your Sandra report shows RAM from 2 different makers. While that's probably not the problem here, it is likely to hurt performance. All RAM should be exact matching sticks(same brand, same size, same part number). I would remove the Hynix(4GB) and replace with another Samsung 8GB stick.
Old 08-26-2020, 04:19 PM
junkgear's Avatar
If it still doesn’t work for you, post a screen shot of the playback engine so we can see what is available. In PTF, you select both the input and output from the Playback engine.
Will
System Details
Old 08-27-2020, 03:53 PM
Hi there,
I have worked through all suggestions but still not working yet
I have added more screen shots including the playback engine - I hope this helps - all help is very appreciated
Cheers - GG
Cheers - GG
Windows 10 Pro
12.0 GB RAM
Old 08-27-2020, 07:37 PM
I just reinstalled PT 1st - still does not show I/O in setup drop down menu. Is it supposed to?
Is this just a PT 1st issue?
If I upgraded would it solve the problem?
Should I buy a new sound card?
Totally stumped
Cheers
GG
Cheers - GG
Windows 10 Pro
12.0 GB RAM
Old 08-27-2020, 08:33 PM
I created a new project from the blues template and got the following error message
Notes
Comments
Missing Inputs
The input "Input 1" on track "Lead Guitar" is not available in the current I/O setup.
The input "Input 2" on track "Rhythm Guitar" is not available in the current I/O setup.
The input "Input 1-2" on track "Audio 3" is not available in the current I/O setup.
The input "Input 1-2" on track "Audio 4" is not available in the current I/O setup.
Cheers - GG
Windows 10 Pro
12.0 GB RAM
Old 08-27-2020, 08:58 PM
Also - I feel like possibly this is an ASIO issue? I don't totally understand where that fits in the setup. Are the ASIO drivers included in the UA DAW? Or do they come with PT? Or should they already be there in WIN 10?
Cheers - GG
Windows 10 Pro
12.0 GB RAM
Old 08-28-2020, 08:17 AM
junkgear's Avatar
The ASIO driver is supplied by the interface vendor, which is UA in this case and you do not need any other driver for it.
Pro Tools first does not include the IO setup window. What should happen is when you bring up the Playback Engine dialog, and select the Apollo USB as the playback device, you should see dropdows for both input and output. From your screenshots, you are just seeing the output dropdown, which I guess means that PT is not seeing the inputs from the ASIO driver and I'm not sure why.
Many people have used the Apollo interfaces with PT, so it is most likely an issue on your system. Unfortunately I do not have any suggestions on what to try next.
I would contact UA support and see if they can offer any advise.
The other option would be to uninstall Pro Tools First and try the Free Trial of the full version of Pro Tools.
Will
System Details
My inputs and outputs are no longer working (hardware issue) stevedresser83 Windows 3 12-28-2016 10:22 PM
Outputs rendered inactive? scorchedwave FireWire & USB Audio Interfaces (Win) 1 06-10-2015 12:10 PM
I/O Outputs CONSTANTLY Inactive MrBibidy Pro Tools 10 1 08-07-2013 06:23 PM
Inactive outputs can't be activated BassGuy33 macOS 10 12-22-2012 09:33 AM
PT9 Lab of 30 M-Audio Fast Track Pro - EITHER 4 outputs OR 2 inputs blackmacdaddy macOS 4 01-27-2011 10:38 AM
