Starting to get random clicks/pops
With only a guitar plugged into the input, and using the headphone out...I've gotten 2 seemingly random noises while playing today. Same noises that I hear during startup or when I change the clock setting. The level of the noise is unaffected by the output volume level. Have yet to lose audio completely like some of the reports on here, but it still bummed me out pretty hard. I've got a Rev D, bought used, and bought the ERXP separately. Is this a sign of the clock issue? As a used buyer, what should I do if/when the problem gets worse? There is a local Digi Authorized repair center where a buddy and I went to pick up a 002 power harness, could they take care of me if this becomes a bigger problem? EDIT: My 11r has been sitting on tuner mode, and made the noise. EDIT #2: Getting rid of anxiety-related grammar problems :) |
Re: Starting to get random clicks/pops
are you sure its not just running out of CPU power in your PT session, or maybe you need to raise your buffer.
Are you recording to your OS hard drive, a slow hard drive or USB hard drive? I am of course assuming you had PT or another DAW open at the time. Or are you talking about standalone?
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Totally standalone. The only cables connected are the power, 1/4" for my guitar, and the headphone out.
Just got another crack a second ago while playing. Like I said, its a similar sound that the unit emits while first starting up, or when I go in change the sample rate. |
Are you sure that the clicks and pops are not coming from the guitar itself?
Input jack? Bad/scratchy pots? Do you have another guitar to use to test? Just trying to eliminate possible sources. |
Appreciate the input, but one of the cracks came through while the unit was in tuner mode with the output muted, and the guitar unplugged.
Edit: I've been keeping my 11r running idly on tuner mode for a few hours while monitoring it through my speakers. Haven't heard the noise since just after my last post, but still feeling a bit anxious about what I heard earlier. I'm gonna keep messing with it over the next few days and keep a close eye (ear?) on it. |
Derker, with the clock failures that we've seen in some units, the problem only occured when the sample rate is changed or at boot up. So potentially what you're seeing is unrelated. In most cases I looked at the clock problems occured at 44.1kHz and not 48kHz, although sometimes vice versa. If you are actually seeing a clocking problem, I would expect that switching to a different sample rate would fix the problem, so that's something to try.
Chris Townsend Guitar Products Architect Digidesign, A Division of Avid, Inc. |
Thanks for the reply, Chris. I have no issues at boot up and nothing seems to change when I switch sample rates. I'll try using a different 1/4" instrument cable for now, and keep a close eye on everything to make sure it's kosher. Thanks again for the response, my anxiety was through the roof. :)
This might be a real dumb, paranoid question but to put my mind at ease I'm gonna ask it anyway:
When you change the samplerate (in standalone mode or when connected to pro tools) is it normal for the sound to "pop" when you do? So I turn the knob from 44.1 to 48 hz and when it says 48 it gives off a "pop". Probably going paranoid here ...
Guitars: Schecter C-1 Blackjack ABSN, Ibanez RGA 121 Amp: ENGL Ritchie Blackmore Effects: TC G Major 2 Awesome: Eleven Rack (with EXRP)+ M-Audio Bx8a's |
Turned my 11r on early today to monitor while I'm doing menial stuff, to see if I get any more stray sounds. So far so good, hoping it was some fluke user error BS. |
random clicks and pops on DX | garnoil | Post - Surround - Video | 1 | 09-27-2010 11:27 AM |
Need help to get rid of random clicks and pops! | Helge Krabye | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 05-25-2008 10:03 AM |
Random clicks and pops 7.4 | wedgewedge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 12-15-2007 02:39 PM |
Random pops & clicks - Protools HD1 PLEASE HELP!! | bensampson | Pro Tools TDM Systems (Mac) | 2 | 03-12-2006 02:50 PM |
Random pops & clicks (not clock related) | DaveGerhart | Pro Tools TDM Systems (Mac) | 8 | 12-08-2005 06:23 PM |
