Help!!! MIDI SD3 issue killing session.
Hey guys, need some help on the fly as this bug is killing me in the middle of a session.
Specs for this: MacBook Pro M1 Pro 16gb ram 12.6 2022.10 studio Clarett interface Running SD3 in a small ish rock session. MIDI is all tracked for the drums. Everything was fine until SD3 just started to stop playing in random parts of the song. Tried making a new track, copying the midi into it, but it causes the same issues. Tried restarting, rebooting, importing into a new session etc. SD3 just keeps randomly dropping out. Tried different buffer settings, different interfaces. I can’t seem to figure it out! Please help as I need to get this back up to finish this session! Much appreciated.
Mac Studio Ultra 64Gb Ram Protools 2021.12 Ultimate HDX 1 HD Native HD Omni HD 8x8x8 HD 16x16 S1 x3 |
Re: Help!!! MIDI SD3 issue killing session.
By SD3 you mean Superior Drums 3.
Try a different drum plugin. If you don't have one, I think Toontrack, Addictive Drums and more have trials that have a limited set of sounds, but might just work as a workaround.
I just export a stereo wav from SD3 and pull it into the session. If you've tracked the drums already then that's the easiest fix.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon. |
Seems creating a new track and new instance of SD3 and putting the midi IN SD3 "solved" the issue.
MIDI in Pro Tools 11 is Killing Me | AgentGFunk | Pro Tools 11 | 1 | 09-21-2015 01:18 PM |
Sync issue, pro tools MIDI and MIDI controller, timing issue | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-29-2011 07:57 AM |
Slow Sluggish Delays Beachballs----killing the session flow | Zep Dude | Pro Tools TDM Systems (Mac) | 5 | 08-01-2007 07:52 AM |
Digi, Your Midi IS Killing me | 25ghosts | Pro Tools TDM Systems (Mac) | 12 | 12-24-2006 07:21 AM |
Is my Reason file killing my PT session? | timmy4402 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-26-2004 12:44 PM |
