Noise on Talkback bus
Hey folks...
I interfaced a talkback mic on the talkback bus this evening, and it seemed to be very noisy. It has a horrible hiss sound in the background. Has anyone experienced this? Possible solutions? There are a couple of other things going on with the console...a few LED's are out and the headphone jack is all sorts of messed up. How does the process of getting a digi repair rep out work?
Ken Miller, Jr. Audio Engineer Southside Baptist Church | Warner Robins, GA | VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Re: Noise on Talkback bus
Hi Ken,
Sorry to hear about this. If this is a new unit please let the service guys know so they can work with our QA to make sure this doesn't happen again. Re: talkback noise. Is the noise only on the talkback channel, or is it also on the solo bus (headphones/monitoring out)? If it's on the channel only, then it could be a bad connection within the console, or in the cable that connects the console to the FOH Rack. Perhaps the balanced connection has gone one-legged somewhere. If it's on the solo bus, check out this link for what I suspect the cause might be: http://duc.digidesign.com/showpost.p...71&postcount=2 Sheldon |
Sheldon,
Thanks for responding. It is an installed console, been in about 3 years. I did check, and it is also in the monitoring buss as well. I tried the trick you recommended, and the noise is still in the talkback line. I did not check the monitor buss though. One day this week I'm going to do a dummy check to make sure something isn't jacked up on my end before I contact support. There are a couple of other little things...such as some LED's aren't lighting up and the port for the headphone connector has worked its way loose. So...either way I may be putting in a call to support. Would the support team be able to setup a site visit to have the desk looked at? Thanks again for your help. Great meeting you last week!
D-Command Talkback Noise. Please help! | sputnikestudios | ICON & C|24 | 1 | 08-06-2014 09:32 AM |
Source Talkback AAX gets auto talkback | MIKEROPHONICS | Post - Surround - Video | 0 | 11-20-2013 08:15 AM |
Venue -Talkback Mic Noise (Pleae try this way) | Jae Hwan Kim | VENUE Live Sound Systems | 11 | 06-07-2006 11:14 AM |
Noise on Talkback | Sam Yin | ICON & C|24 | 0 | 01-11-2004 01:37 AM |
Attn: Drumkit from Hell experts: noise noise noise | Smelt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-30-2003 06:31 AM |
