External drive - 924 or 934 chipset?
Looking to upgrade my external drive from Lacie 100G to OWC 1TB. Noticed that the newer ones have the 934 Oxford. Is this a newer version of the 924 Oxford and is it compatible with PT?
Thnx for your responses! Mac Pro 16 G RAM, 2.8GHz, 8 core 10.5.8 OSX PT 8.0.1 |
Re: External drive - 924 or 934 chipset?
AT this point, it looks like all the Oxford chips are okay.
If you have a Mac Pro, why the external drive?
Make sure you have current backups.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
For sure, I would use internal SATA drives first. I pretty much only work on internal drives(better performance) and use externals for moving sessions between studios.
Thnx - I just upgraded from MacBook Pro to Mac Pro and am unaware I can now use the internals instead of external HD's. Being new at this, I have been careful to always store my audio off of my computer and onto externals. Not neccesary anymore??
Pop the side panel off the Mac Pro and you will find 4 aluminum brackets(the front one has the system drive). You can install 3 more SATA drives in those extra caddies. Search youtube for "mac pro drive replacement" or similar and you will see videos on how easy it is.
Thnx Albee for the help! Looks like I have 3 drives installed - 1 - 320G, 1-TB, 1-TB - total 2.32TB and I am just using the 320 as SYstem drive and 1TB for backup. Seems like I have a spare TB drive to store sessions. Need to figure out how to redirect PT to read the internal instead of the external Lacie.
Thnx again!! |
If you want to create a new sesion on that drive, just select the drive in the New Session window. |
How to identify chipset in external hard drive? | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-30-2012 05:26 AM |
Oxford Chipset external HDDs in the UK? | markytorture | Pro Tools M-Powered (Win) | 1 | 05-24-2010 09:17 AM |
External drive Oxford 934 chipset | MortyKvack | Pro Tools TDM Systems (Mac) | 5 | 11-04-2009 05:01 PM |
External Hard Drive Chipset Links | Rob0214 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-29-2008 11:11 AM |
External FW Enclosure - Cypress Chipset | ChrisMitchell | Pro Tools TDM Systems (Mac) | 6 | 10-16-2007 05:05 AM |
