Old 04-10-2017, 06:26 PM
Leyenda Productions Leyenda Productions is offline
Default Need a Windows Audio Interface for Windows PC
I'm currently using a focusrite saffire pro 40 and having so many problems
When i open projects and hit play it freezes and have to restart​ a few times i know for a fact that is a driver issue with the saffire pro. I have tried everything to get it working properly the problem happens randomly but im ready to move on and get a different Interface. Any suggestions?
www.LeyendaProductions.com
Old 04-10-2017, 07:47 PM
sw rec sw rec is offline
Default Re: Nedd a Windows Audio Interface for Windows PC
Make sure Windows is NOT using the Saffire as the default audio device.
Old 04-10-2017, 08:57 PM
Made sure that was not the case since day one. Still having prpblems
Old 04-10-2017, 09:10 PM
From my reading, RME seems to have the absolute best drivers.
Old 04-10-2017, 09:14 PM
I have been thinking of getting the RME UFX
Old 04-10-2017, 09:16 PM
The funny thing is that i never have any issues when running samplitude,studio one or cubase with the saffire pro 40. Only with protools i see those problems
Old 04-10-2017, 09:18 PM
The drivers seem to have clocking problems and lock up in PT
Old 04-11-2017, 10:07 AM
The Weed's Avatar
The Weed The Weed is online now
Yes to RME. I have the UFX and indeed the drivers are rock solid. RME write their own USB drivers and support their hardware for years and years. USB 2.0, with RME's drivers, is more than capable for the UFX's I/O and as good as or slightly better that FW400 (yes I tried both, I moved up from an 002 Rack, with an approved SIIG firewire card).
That said, I did have a crackling issue at first, but solved it. See this thread.
Everything is stable and fine with PT now (W10 Pro AU, PT 12.7.1) although I don't stress PT anywhere near what most do.
The UFX is a real, pro piece of kit. You can even record to an approved USB stick without using a computer, or as a back up. Mic pres are absolutely usable, FX, at a minimum, is good for monitor mix and the converters are clean and pristine, some would say sterile, but they will allow tracks to stack up in a mix and with no color, you can process the audio anyway you want.
TotalMix, the software mixer, is a steep learning curve, but very effective.
RME is not cheap, but definitely worth it.
HTH
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-11-2017, 11:35 AM
HTH
thanks! i will probably end up getting that same interface
Old 04-15-2017, 04:21 PM
mdvirtual mdvirtual is offline
I just upgraded from an MBox Pro to an Fireface UFX and I love it! Took a bit to get used to TotalMix but once you get familiar you can set it up to do just about anything you need.
Running 12.3 beautifully in Windows 7 Pro
Michael Damon
Composer/Sound Designer
Virtual Productions
PT Ultimate, i9-9900k, 64GB RAM, Gigabyte Aorus Ultra MB, Sapphire Radeon RX580, Windows 10 Pro, Fireface UFX
Audio Interface Issue with Windows 10 Connor Windows 20 04-22-2017 09:50 AM
How to change audio interface used in Windows - Pro Tools 9? thisjanuary Pro Tools 9 5 10-11-2016 03:37 PM
M-Audio interface for Pro Tools 11 on Windows 8.1? Analogica1 Pro Tools 11 2 02-05-2015 05:05 PM
Pro Tools and M-Audio Interface won't work with Windows 8 burritobandito Pro Tools SE and Essential (Win) 9 01-02-2014 10:17 AM
Audio Interface for ASUS Windows 7 Laptop Darzel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-27-2011 05:26 PM
