PT Not Recognizing Second Interface
Hey Everyone! I have a Rosetta 800 and I just bought a 96i to get some more inputs but I can't seem to get Pro Tools to recognize the 96i. While I'm in Pro Tools, under my I/O and hardware setup, there's only a single 192 (the Rosetta 800). I've run DigiTest and it said that the Test Status is "Failed" (even though it seems to work fine). On the Results tab it also says "Peripheral Digital Loopback Test - Channels 1 - 16: Failed"... and if I show all results it says "Peripheral Digital Loopback Test - DSP B: No Secondary Peripheral Found". Another curious result, is that under the Slot Info tab, under "Secondary Peripheral Information", "Peripheral Family: Firmware Missing!" Admittedly, I'm not so savvy with DigiTest, but I thought that I'd try going to the Audio I/F Firmware tab. If I select "Secondary", "Type:96i", and begin update, it says "Programming Failed: Data Verification Error". Any suggestions?? Thanks in advance!!!
Ryan McCambridge Producer • Sound Designer • Mixer |
Re: PT Not Recognizing Second Interface
Just a guess, but have you tried putting the 96i first?
I haven't actually... I will try that later today. Even still, I'd like the Rosetta 800 to be the master for clocking, as well as the first converter in the chain of i/o (since it has a matched number of ins and outs)... as opposed to outputs 1 & 2 being from the 96i, and then 3, 4, 5, etc. being from the Rosetta. It's not the worst thing, but it's just a bit awkward.
Okay... so putting the 96i first worked - Pro Tools recognizes everything. It's a bit of a work around, but I'll just change the internal I/O routing in Pro Tools to make up for the Rosetta not being the first interface. I'll also get PT to clock from the Rosetta in the hardware setup. The only thing that's odd now is that I can only get 16 inputs going. I'm recording 24/48, 2 DSP's... I've added 24 inputs in the I/O Setup, and routed them appropriately, but when I go to a track to select an input, it just shows the first 16. Any thoughts on what's happening there? Thanks again!! Ryan
[quote
The only thing that's odd now is that I can only get 16 inputs going. I'm recording 24/48, 2 DSP's... I've added 24 inputs in the I/O Setup, and routed them appropriately, but when I go to a track to select an input, it just shows the first 16. Any thoughts on what's happening there? Thanks again!! Ryan [/QUOTE] Hi, Just check that all the inputs you created in the i/o setup have the box ticked to activate them. also check that the same inputs and outputs are not assigned to inserts (as they can not be assigned to both inserts and inputs!) and inputs 17 -24 are they assigned to digital format? if above settings are not the answer then start looking at the digital settings for 17-24. Chris
Please Hi please I need help, my computer is not recognizing 11r as audio interface | BetoRock | Eleven Rack | 2 | 03-08-2014 09:47 AM |
pro tools not recognizing unitor 8 usb midi interface | blujway | Pro Tools TDM Systems (Mac) | 7 | 02-25-2011 03:01 PM |
2 Problems: PT not recognizing plug-in and CPU not recognizing external hard drives | jasonguitar | Pro Tools M-Powered (Win) | 0 | 06-28-2009 06:32 AM |
protools not recognizing digi001 as midi interface | seasondigital | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-31-2007 08:46 AM |
MasterlistCD not recognizing new Card and interface | rojo | Pro Tools TDM Systems (Mac) | 2 | 06-14-2003 12:02 AM |
