Problem after install ProTools HD 7.3.1cs5 update for MACOSx
Hi!
I have a problem. Please help for this. I install ProTools HD 7.3.1cs5 update for Mac OS x and i have already installed ProTools HD 7.3.1. After instaling and reboot sistem , start aplication ProTools and apear messages: " Could not open session because You do not have apropiate acces privileges(-5000) while creating "Grooves" " I tray start new sesion and messages apear again. Thanks for your attention and give me please solution for rezolv this problem. Sincerly Onut Simion! |
Re: Problem after install ProTools HD 7.3.1cs5 update for MACOSx
Did you repair the disk permissions after the upgrade?
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
Hi!
Thank you for response. I have permissions on disk. I wish uninstall this update , but i don't have a solution. |
You may have permissions on the disk, however there have been cases where installs/updates change permissions for specific files and directories, so using the disk utility to repair the permissions should be one of the first things you do when you see something like this. It may not be that YOU don't have specific permission, it could be that the write bit has been turned off.
'Repair Permissions' won't have any effect on the actual permissions that a folder may have, which is likely the case here.
Go to MacHD>Applications>Digidesign>Pro Tools and 'Get Info' on the Pro Tools folder. In the Ownership and Permissions section, make sure they're set to: Owner = your account Access = Read and Write Group = Admin Access = Read and Write Others = Read and Write Then click on 'Apply to Enclosed Items'. That should fix it. |
Similar problem
MPowered Pro Tools 7.1. did the MP 7.1cs10 upgrade, said it finished, now Pro Tools won't Launch at all. No errros, just no Pro Tools> ouch |
Have to install pace extension software each time I start Macosx before PT9 will load | belolab | Pro Tools TDM Systems (Mac) | 11 | 07-27-2011 05:23 PM |
Pro Tools 7.3.1cs5 update Problem on Macbook pro | joeldadrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-07-2007 03:23 PM |
Pro Tools LE 7.3.1cs5 Update | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-02-2007 11:17 PM |
Pro Tools HD 7.3.1cs5 Update | Avid | Pro Tools TDM Systems (Mac) | 0 | 10-02-2007 10:44 PM |
OMS won't install on macOSX .help! | Belle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 02-24-2004 10:20 AM |
