Hard Drive Recovery Service?
I have a problem with my main Pro Tools drive.
It is a internal SATA Seagate 500 gb drive. The SATA connector that connects the drive to the motherboard broke. Where the SATA cable connects to the drive itself is a piece of plastic that fits inside the SATA cable. This plastic piece has broken somehow and the pins are no able to touch. So the OS and the BIOS does not see it. Can anyone help here or suggest a service who can fix this drive enough to get the data off? Thanks
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
Re: Hard Drive Recovery Service?
I sent my original 750G SATA internal Seagate and they fixed it free as it was a mechanical problem. Call them, I got mine back with a data intact.
Doc |
And do you have their number? Thanks
It probably went to Seagate so check their website for contact info. If you could buy another of the exact model and version, you could move the circuit board to the broken drive and likely access all your data to copy it to another drive. This will be a hard-learned but well-learned lesson regarding backups. If your data doesn't exist in 3 places, its not properly backed up(not nagging here, but its a lesson I learned a while back and won't suffer over it again....fingers crossed, but data is backed up on multiple drives. Data recovery services are very expensive.
This is the route I chose to go earlier. Just ordered the HEX drives and found the same model seagate on ebay for cheap. I did talk to the folks who handle DATA recovery for Seagate today. They said it would be $1200 to recover the DATA. So I pray this will work. On the lines of lessons learned. This event has been hard to swallow. The drive holds music the Lord has given me from the past year and a half. I am asking for His mercy here. Please be in agreement with me that the Lord do a miracle with this. Thanks
Weird that they charged you for data recovery. Since it is a hardware failure... you said it was a connector that broke, as opposed to a hard drive issue with the internals. My problem was with the ROM on the drive, and they had to flash it and re-install... whatever they do.
I'm surprised a connector would cause them to have to open the drive. The reason for the cost mostly being the clean room. Anyways, I learned this lesson in the exact same way, and I think Albee was the one to offer advice then as well! Now I have 2 external 250 drives with archives on them... same stuff on both drive. My main OS drive, a 750g work drive, and a 2TB drive that stores the Time Machine Backup of my OS drive and a copy of the work drive. I know it's not a triple backup system... but that's the next step. For bigger studios, its always worth getting a 16 drive raid system, or using online backups and offsite storage. You can put a price on your hourly, but you can't put a price on your backup drives of the client's album. Doc |
Used Data Recovery Service for Hard Drive and now cannot open sessions. | seahorsesoundstudios | Pro Tools 10 | 5 | 02-06-2023 02:10 PM |
Hard Drive crash - service recommendation needed | gregfrey | Pro Tools TDM Systems (Mac) | 2 | 05-31-2007 07:38 AM |
Drive recovery or file recovery | bobmaus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-13-2006 03:00 PM |
new hard drive/windows messenger service | Detuned6 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-30-2005 02:45 PM |
hard disk drive recovery..... | Seeee | Pro Tools TDM Systems (Mac) | 1 | 09-01-2004 01:35 PM |
