M-Box Mic input question
I had just finished recording acoustic guitar tracks using the 'inst' level input and a TRS connector. No problem (by the way thanks to whoever for the help regarding the hardware buffer!).
I then wanted to set up the SM-58 for some scratch vocals. I plugged it into the mic input (using XLR of course), made sure that the "mic" light was lit on the Mbox input 1, armed the track, and got practically no signal into PT until I cranked the input level on the MBox all the way. I switched to the Mic input 2, changed the input on PT for that track to Mic/Line 2, set the mic input switch for input 2 on the Mbox, armed the track- same result. Again, my inst/line inputs are working fine. Is this a problem with the mic-preamps inside the MBox??? (its practically new- August '05), or am I missing something obvious?? Thanks in advance for all helpful replies VeMan |
Re: M-Box Mic input question
you did turn phantom power on, right?
SM-58's are dynamic and don't require phantom power...
Dean |
Although, yes I did try that knowing that SM-58s aren't phantom powered. Thanks, though.
VeMan |
they dont requite phantom power, no. but using it will increase the level of the signal.
if that didnt work i dont know |
SM 57 and SM58 are dynamic mic's, and may seem a bit unsensitive. Just put them very close to the source of the audio and you'll be fine. Or get yourself some condensors. Also make sure you use balanced cables. some cheap XLS-cables feature XLR-plugs on either end, but only have ground and signal inside.....
What's that? - That's the machine that goes "pling". Bastiaan |
It's not unexpected that you'll need to raise the gain control on the Mbox mic preamp. The Mbox preamps don't have a large amount of maximum gain, and the SM58 does not put out a very large signal.
Quad 2.5 G5, 4.5G RAM |
The mic cable is proven OK?
Sorry to ask the obvious....
Bob Without a song The day would never end |
Thanks again for help on this. Anybody else have any ideas? More importantly, is it possible to screw up the mic preamps on both imputs if a line- or instrument-level signal happened to come through on the mic input?? VeMan |
Obvious is good! VeMan |
Input question | RettRobinson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-05-2010 10:36 PM |
Input question | RettRobinson | Pro Tools 9 | 5 | 11-05-2010 10:21 PM |
M-Box 2 Pro input question | BobAboard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 04-06-2009 08:08 AM |
192 input question... | Eric Lambert | Pro Tools TDM Systems (Mac) | 4 | 03-22-2008 11:03 AM |
001 Input Question | infradig4 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-14-2006 05:43 PM |
