Old 07-19-2010, 06:39 PM
Mikhail Mikhail is offline
Default Can't drop markers with Enter key!
I really hope this issue has an easy solution. I've just upgraded to 8.0.4 on Snow Leopard / Macbook Pro, and I can't figure out how to drop markers. Function+return doesn't work (this laptop has no separate enter key) and my external keyboard thinks the "enter" on the numeric pad is for "play" instead of "add memory location." I'm out of ideas. I've used Pro Tools 6.8 before on an old powerbook, and everything was fine.
Also, I can't right click to scrub anymore?
Thanks a lot guys - I need this for work, so I'm really screwed if I don't figure this out soon.
Old 07-20-2010, 12:50 AM
tamasdragon tamasdragon is offline
Default Re: Can't drop markers with Enter key!
First, yes, macboopro's doesn't have numpads, so fn+return wouldn't work.
But!
Look at setup/preferences/operation tab
There you can find some numeric keypad settings...
my blog:Tamas Dragon
Old 07-20-2010, 08:00 AM
Slate416 Slate416 is offline
Don't know if other's have had any luck with this, but I downloaded the KeyRemapper4MacBook, remapped some of the keys, and it works perfectly. I can hold the fn key and use my keyboard like a numeric keypad if i need to.
http://pqrs.org/macosx/keyremap4macbook/
-Chris
Old 07-20-2010, 08:08 AM
Dism Dism is offline
Does the new Macbook Pro not have an Enter key?
Mine definitely does... and it even drops markers. Should be to the right of the spacebar...?
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 07-20-2010, 01:03 PM
But!
I switched to "classic" and it works now! Thank you!
Old 07-20-2010, 01:04 PM
nope, the enter key is now function+return. I got this computer less than a month ago, so it's possible they just changed it recently.
Old 07-20-2010, 01:07 PM
and just to be clear, scrubbing with the right mouse button is gone forever now? No way to do it without pressing "control" ?
Old 09-06-2010, 02:51 PM
EllenF EllenF is offline
fn and enter key work for on the fly memory locations dropping on MacBook Pro.
Beat Markers Appearing As Elastic Audio Markers Fabdickson Pro Tools 9 1 03-06-2012 05:03 PM
How to turn all Event Markers into Warp Markers ??? fman Pro Tools TDM Systems (Mac) 15 04-29-2011 01:46 PM
Enter Markers/Mem Loc using D-command kimlau ICON & C|24 3 01-05-2009 07:27 PM
how to drop markers EyelashoutEnt Post - Surround - Video 6 05-12-2005 10:26 AM
Can't enter memory locations with "enter " key? bhooligan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-06-2005 01:42 PM
