JAM 2.5 does not work with Yamaha 6416
What a shame, I was so happy waiting for my Jam 2.5 from macmall and oops I forgot to check for compatibility, JAM does not support my yamaha 6416.
Does anyone knows if adaptec is coming out with something so it would be compatible? And when? I checked their page and I found NOTHING. Any1 want a cheap JAM? lol |
Re: JAM 2.5 does not work with Yamaha 6416
Did you check out yamaha's website, I have the 8/4/24 and it also didn't work with Jam,..............I found the Jam 'driver' on the Yamaha site,........strange huh? I can't recall the URL cause I'm at work now and all my music stuff is at home, but it can't be hard to find. Check it out!
Yo kickin my man,..........howzit banging?!?
Just trying to figure out those neato smileys N. |
hey corbel - don't dump your jam yet! ( a little too graphic?). There are 2 patches available for the 6416 @ www.glyphtech.com -
1 for cd-rom toolkit and 1 for jam 2.5! Just download it & put the patch in your jam folder. I just used it last night, jam recognized the 6416 w/ no problem and burned the cd. Now if I can only figure out how to set-up my ptle tracks so they all burn in stereo! Patience I guess! Anyway I hope this helps. peace crow
___________________________________________ Mac Pro 2010 2 x 2.66 / 40GB RAM / OSX 10.13.6 / PT2020.5 / Metric Halo ULN-8 |
Has anyone else experienced problems with clicks and pops with the Yamaha 8424 and Jam ? If I use Jam to insert space between tracks, when I play the disc, I sometimes get a pop right as the track ends and the space begins--it sounds like the beginning of the next track gets played for a split-second...
But, the problem is not with the tracks, and if I play the problem areas from Jam, I don't hear the pops--they only show up on the burned CD. Anyone else experienced this ? If I set the between-track time to 00:00, everything works fine--I only get pops when inserting space between tracks. James [email protected] |
jnash,
use the fade in and out function in Jam. Since system 8, I have had some problems with this pop sound, with Jam and any CD burner or MLCD and any CD burner. Same hardware system 7.5.5 /7.5.6 works fine. Regards e |
Editor,
Thanks for the advice--I'm glad to hear there's a workaround. Sounds like Jam needs a bug fix update... I've never had this problem with Toast. James [email protected] |
Thank you everybody for your help But; I went to both links and looked for it and it never worked in the link to glyphtec.com I never fund it, I download the one at Yamaha.com I put it on my jam folder but still doesn't recognize it.
What am I doing wrong????? please. |
corbel,
Are you sure you have installed the patch for Jam and the Yamaha 6416... This file goes in your Jam folder...see below. http://www.glyphtech.com/help/patche...W6416S.sit.Hqx The firmware update is available here...see below http://www.yamahayst.com/techsup/download2.htm The patch belongs in the Jam folder, The firmware is used to update your Yamaha 6416 CD burners firmware. Read the "Read Me File" that comes with the firmware download, to use the updater and follow the directions carefully. Regards e |
Adaptec 2030 and Yamaha 6416 | bugsy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-01-2000 09:46 PM |
Patches for Jam 2.5/Yamaha 6416, Yamaha 8* and a lot of essential patches. | editor | General Discussion | 10 | 05-20-2000 08:29 PM |
Problems with Yamaha 6416 burner | Corey Shay | Tips & Tricks | 3 | 04-17-2000 03:06 PM |
which card for the Yamaha 6416 | corbel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-27-2000 06:02 PM |
Yamaha 6416 2x burn no go??? | Przemek | Digidesign Hardware & Software | 2 | 09-10-1999 02:51 PM |
