problems importing I/O bus template
Hi
I`ve spent some time setting up a custom bus template in the I/O setup. It I have basically made names to match my mixing template session that have alot of aux tracks etc.for mixing. the bus template doesn`t seem to work. Heres what I do 1. opening the session I`m going to mix. 2. importing session data and my mixing templates with aux tracks etc 3. importing the custom bus template made in the I/O setup After importingm, everything is just a mess. some buss routings are correct but others have no names and so on. How is the best way to get the bus template I created exactly right when importing? thanks |
Re: problems importing I/O bus template
I do it the other way around! i open a new session from my mixing template which obviously has all my busses and routing in place etc. Then i import the song with import session data into the new mixing session. I only import regions and data and the midi map and locators if needed. the new imported tracks default to my mix bus output and any that i want to bus can be done quickly and easily and voila. I always open a sessions i receive first to check they are all playing ok and everything is labelled and anything unused gets deleted etc, then i know i'm importing the right stuff and only what i need!! Chris
Importing session data from a template | King of Spain | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-12-2008 09:25 AM |
TEMPLATE Problems | KJVMBird | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-01-2007 05:24 AM |
Loosing TEMPLATE setting when "importing audio" | KJVMBird | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-26-2007 09:18 PM |
Template Problems | BenTerry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-07-2004 03:22 PM |
Importing tracks into a template or viceversa? | marcelloz | Pro Tools TDM Systems (Mac) | 1 | 10-22-2001 09:02 AM |
