Sync Pro Tools as slave to other composing DAW
I need to host video inside Pro Tools, and set is a slave. I will be composing using other DAWs (Studio One, Logic, Reaper) so that they can be the "master" and will also need to record the output of my composing DAW into a stereo track in Pro Tools. More or less what happens in this video: https://www.youtube.com/watch?v=YLayIcGWsDQ&t=627s I have only one computer (Mac Pro) and only one audio interface. I was not able to achieve this even after trying multiple guides found online and on this forum as well...would anyone be able to help me get my head around it? Thanks so much and all the best -m
Mac Pro 2013 6-core 64GB Ram Motu M4 Pro Tools 2021.6 Last edited by mikeheels; 07-19-2021 at 03:27 AM. |
Re: Sync Pro Tools as slave to other composing DAW
You can use MTC to send/receive from one DAW to another within the same machine. Look into your Audio MIDI Setup > MIDI Network Setup window. Create a session and set your DAW accordingly.
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
The article is from 2009 so I assumed that was the reason. |
Principle is still the same. But let me try if memory serves me right.
First you want to set Logic for MTC and MMC send, then on PT set MTC reader port to "any" and you should find something that says Logic Sync in MTC generator port. IAC Driver or something, you would see this name in Audio MIDI Setup. PT MIDI Machine Control also need to be enabled, as well as MIDI Beat Clock delay compensation. Hope this helps.
All the best -m |
No problem. I hope you get it going.
5. You'll want to make sure that both of your audio interfaces for Logic and Pro Tools are synced to the same clock, so you should connect a digital out from your Digi HW to a digital in on your Logic hardware. You can use ADAT or SPDIF (RCA or Optical). Make sure your Pro Tools session and Logic session are set to the same sample rate - in Pro Tools this is set when you create the session. In Logic you can set this in File>Project Settings>Audio. AFAIK, PT does not allow concurrent use of Avid interfaces. So, if OP is using Avid IFs then this might fail, that is, PT runs with IF and Logic runs with internal or vice versa? You would need a tunnelling protocol like ReWire or virtual interface like Blackhole driver (https://github.com/ExistentialAudio/BlackHole) or similar (e.g., Rogue Amoeba products http://rogueamoeba.com)—maybe as an aggregate device—for inter-process audio transfer.
Best, Kevin Last edited by theAlien; 07-18-2021 at 04:50 AM. |
It can be done with single interface, if the single interface can be shared with multiple DAW. Also, I got the impression that PT only need to be slaved to show video, interface is irrelevant.
EDIT: I have synced PT and Logic with a single Apogee Symphony mkII
OP says: "... and will also need to record the output of my composing DAW into a stereo track in Pro Tools."
Best, Kevin |
MPC LIVE II, Pro Tools HD 10, MOTU XT Midi Sync Pro Tools Slave | $BIGGROBB$ | MIDI | 0 | 10-10-2020 11:14 PM |
Pro Tools (Master) sync (MPC 2500 Slave) troubles... | Connecticut | macOS | 2 | 07-06-2011 06:16 PM |
Sync Pro Tools (master) and Logic (slave) | tonicjeff | Pro Tools TDM Systems (Mac) | 2 | 02-22-2008 08:56 AM |
midi time sync my motif as the slave and pro tools | DMAN2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-20-2005 08:05 PM |
sync triton as master to pro-tools as slave? | eddybertrand | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-13-2001 01:21 PM |
