Re: PT HD 12.5.1 Cant play DNxHD QT !!!! WTF !!!
So looks like an OSX issue rather than a ProTools issue
Felipe Gonzalez A. Avid ACSR Elite Dante Certified http://felipousismix.wix.com/felipousismix Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins |
"I am on PTHD 12.5.1, Yosemite 10.10.5 and running an HDX2 system on a Mac Pro 5,1. DNxHD quicktime files (not MXF) playback fine on my system. What kind of video card do you have in your Mac? Also, what are your settings in the Preferences/Operation tab bottom right corner? Do you have Enable GPU checked?"
OS : Yosemite , latest Graphic Card : Nvidia GTX680 VideoOutput via Graphic Card (Fullscreen) or via Decklink Intensity HDMI ...both outputs same effect with theese Files , Video Hardware enabled or not , no difference ProRes codecs work fine btw GPU is enabled , Avid PE and LE codecs reinstall , no difference
foley artist , soundeditor |
Yeah the new Quicktime player is utter garbage. I still use QT7 Pro to play and convert all my video files. Even the "Get Info" window in the new quicktime is completely useless... it doesn't show anything in there AT ALL. Want to know how many audio channels there are or what format? NOPE. Anyway, I digress.
Not sure what the issue is, and since the files playback on your PT10 system, I can only guess that it's a corrupt preference or something of that nature. I assume you've done the full sweep/clean up routine?
---------------------------------------------------- MacOS 12.4 / Pro Tools Ultimate 2022.4 |
there seem indeed problems within the videofiles...
when opening theese files in PT10 and use "Bounce to QT Movie" for a small part of the video , i can play this from PT10 (via QT i assume) exported Video in PT12 ... but not the original file , even it has the same settings.. go figure
Video Codec dnxhd | Sid0 | Windows | 11 | 01-10-2019 05:49 PM |
H264 conversion to DNxHD | MIKEROPHONICS | Post - Surround - Video | 21 | 06-30-2016 08:47 AM |
PT11.3.1 wont play DNxHD Video..PT10 will | peterle | Post - Surround - Video | 7 | 06-05-2015 02:21 AM |
Bug: DNxHD 36 Color levels 709 vs RGB | mgoorevich | Post - Surround - Video | 0 | 03-14-2013 05:39 AM |
DNxHD Codec and HD Native don't mix | ggegan | Post - Surround - Video | 7 | 02-05-2013 06:20 PM |
