Old 06-03-2015, 02:43 AM
peterle peterle is offline
Default PT11.3.1 wont play DNxHD Video..PT10 will
Its driving me nuts and i cannot find a solution to this problem:
Dual Boot on Mac Pro 4.1 , 24GB , Ati 5870 ,
Decklink Intensity (PCIe OFF on PT11)
A:
PT10.3.9 HD and PT11.3.1 HD on OS.10.8.5
B:
and PT11.3.1 on OS Yosemeti
Videofile : DNxHD 24fps , exported with 50% with MPEGStreamclip
when importing the videofile , even in an empty session , PT 11 ,
BOTH installations , shows still frames and while scrubbing with the mouse,
but the picture is NOT running in playback in the Video Window
In PT 10.3.9 it works fine ....
QT 7 pro , plays the file on both installations fine...
any help?
foley artist , soundeditor
Old 06-03-2015, 03:34 AM
Default
What exact codec? 36? 115? 1080P? 720? What BM driver version? Did you use some "exotic" settings for the export? Like interleaved or changed frame-order etc.? 10 plays it fine because QT does and 10 uses the QT engine. 11 uses the AVID engine which explains the difference you're seeing. f.
Old 06-03-2015, 05:01 AM
Default
just simple 1080p 24 ...nothing exotic , plain preset with the
source having the same framerate etc.
Quality 50% resulting in 4-5 MB/s
and no error message or similar from PT11 , just the still Frame
from the start which changes to the actual Position when hitting stop
Old 06-03-2015, 05:39 AM
Default
DNxHD offers 36, 115, 175 (8-bit) and 175 (10bit) codecs at 1080P/24. Which one did you use? 36 is usually 36Mb/s so that about the 5MB/s you mentioned. Never seen anything lower, but I always use 100% quality. Can you try to make one with these settings: DNxHD 1080P/24 36 8-bit 100% quality Color levels 709 Alpha none deactivate any interlaced options in MPEGStreamclip's export options. You also didn't answer the question about the installed BM driver version. Any more info there?
I use DNxHD36 at 100% all the time in the same version of 11 without issues so could be the BM driver.
Old 06-03-2015, 06:25 AM
Default
it is indeed 36 , 1080p 24 , i wanted to avoid a to high data rate
since the Video is supposed to reside on a Network volume where
bandwith is a bottleneck sometimes , .....
but i made all tests with the videofile on local hd`s
so the Network isnt an issue here
btw since the PCIe out Option is disabled in my PT11 the bm Driver
should not affect the video-window .... at least SHOULD,
the bm Driver is the latest , at least on yosemite
i can only Export the file with 100% (not sure which datarate it will be)
and try if that works , but the last Export took 5 hours..
Old 06-03-2015, 06:53 AM
Default
Try just a small segment for testing not the whole film.
100% Quality setting will give you a 36Mb/s (4-5MB/s) movie. The 50% quality slider will just degrade the image without really giving you less bandwidth.
Also even full 36 or 115 shouldn't be a problem at all when played back from a drive. I wouldn't recommend playing video from a server unless you are using iSCSI or something other SAN.
Not sure what PCI option you mean. Under 11 there's a "disable video hardware" option. Is that the one you are talking about?
Over here I see absolutely no difference in CPU usage with that on or off.
Old 06-03-2015, 07:02 AM
Default
..i meant disable Video Hardware , disable pcie is in pt10 the Option ,
the Server is as backup and storage for older Projects used ,
which are not needed on local drives but can be accessed quickly
for simple playback or editing purposes via Network volumes
Old 06-05-2015, 02:21 AM
Default
a new export with 100% setting made the film compatible with PT11,
BUT after few edits in the video track the symptom . as stated above ,
came back ( its one video file splitted , in the PT-video track , in regions with 6 reels ) after few edits and moving in and out points within the video track
This time i used again DNxHD 1080p24 36 8-bit , quality 100%
There seems to be still a problem in the video-engine....
HTML code is On
Video Codec dnxhd Sid0 Windows 11 01-10-2019 05:49 PM
PT11.1.2HD on OSX10.9.2 Wont play after bounce Boe Larsen Pro Tools HDX & HD Native Systems (Mac) 5 03-03-2014 09:43 PM
PT10 - no sound from speakers now wont even play... DefbyMisadventure macOS 1 01-07-2013 09:01 AM
Video Satellite LE, Decklink, DNxHD - How? SHUK Post - Surround - Video 3 05-12-2011 05:14 AM
Video Satellite LE + AVID DNxHD RenderBot Post - Surround - Video 3 07-15-2009 03:30 AM
