DNxHD Codec and HD Native don't mix
Really having a lot of problems with the DNxHD codec running within Pro Tools on my HD Native system. Lots of 9129 and related errors. If I take the picture off line or swap out the picture for a DVCProHD version exported from QT 7 Pro, the problem goes away.
Since it is an AVID codec, one would think that it would be more compatible with pro Tools than it seems to be.
Gary Gegan |
Re: DNxHD Codec and HD Native don't mix
Why would it matter that it's an Avid codec? Pro Tools is just piggybacking on Quicktime Player, it doesn't have anything else special in there specifically for Avid video codecs.
Any codec that requires a lot of CPU to decode is going to run poorly in Pro Tools. I usually use ProRes 422 (Proxy), works pretty well. |
It's a great workflow, IMO. Transcoding to Prores takes for ever and the files are huge (about 5 times as large) at no better quality. frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Works fine on many systems.
Reinstall the codec. |
Gary Gegan |
Yes you can. Open in QTpro. Export. Hit options. Select DNxHD under options. and pick DNxHD 8-bit 1080p/24fps (or what ever you're working at) under 'resolutions' in the compressor settings.
Found it, thanks, Frank. Somehow I missed it last time I looked.
Gary Gegan |
DNxHD36 worked fine, but I tried moving my HD Native and Decklink cards to different PCIe slots, and now I seem to be able to run DNxHD176 without any problems. I moved the Decklink to the 16x slot and the HD Native to the next 4x slot of my Mac Nehalem, which is the opposite of how I had it before. This is how Avid recommends ordering the cards, which for some reason I didn't do when I did the initial installation, perhaps because I didn't have a Decklink card when I bought HD Native.
Gary Gegan |
Does HD native or native native disable plugins when monitoring inputs? | BasketCase | Pro Tools HDX & HD Native Systems (Mac) | 7 | 05-20-2013 08:48 AM |
Bug: DNxHD 36 Color levels 709 vs RGB | mgoorevich | Post - Surround - Video | 0 | 03-14-2013 05:39 AM |
Video Satellite LE, Decklink, DNxHD - How? | SHUK | Post - Surround - Video | 3 | 05-12-2011 05:14 AM |
DNxHD Quicktimes and Decklink (non-satellite) | potatohead | Post - Surround - Video | 5 | 07-23-2009 10:31 AM |
Video Satellite LE + AVID DNxHD | RenderBot | Post - Surround - Video | 3 | 07-15-2009 03:30 AM |
