need os9 procontrol help
I recently seem to have lost my ability to use my procontrol.
I am on os9.2.2 PT 5.1.? It seems there are two enet0 choices coming up when I scan the port. It can't find the procontrol. any suggestions? thanks rich |
Re: need os9 procontrol help
bump. I hear crickets
How about in the setup page in ProTools? Ethernet controllers.
bookerv12 |
Activating a build in Airport card can cause two enet0 choices instead of one. Maybe you (or a Mac crash and restart) accidentally activated the Airport card if you have one installed? If so, the best thing to do is to delete the Airport extension from your Extension Folder and/or remove the Airport card, so it can't work anymore.
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
IIRC, I've seen something similar to this happen on a Windows XP installation of PTLE 7.1, when a wifi network adapter was activated. I disabled the wifi card & all was well. HTH & best of luck!
I believe that it is the airport card situation that Delta Music Belgium suggested. I had installed an airport card but never got it going. Also had a series of crashes recently. I had a crazy CD with a paper label from another studio that the drive refused to see and locked the computer up.
In trying to eject it after a few hard restarts, I was able to get the machine up and going, but with no procontrol. After I went in an finally made only the base extensions active, no more problem. Now the machine is working great! thanks everyone for their suggestions! rich www.midwestaudiorecording.com |
ProControl with 7.0/7.1 LE (procontrol.dll etc) | eccles | ProControl, Control|24, Command|8 | 0 | 09-17-2010 12:06 AM |
ProControl or C24 | guitar012001 | ProControl, Control|24, Command|8 | 3 | 08-09-2009 05:02 PM |
ProControl with LE? | megahurt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-30-2007 12:13 AM |
6.7 and ProControl | Will Russell | ProControl, Control|24, Command|8 | 1 | 11-05-2004 04:37 AM |
What ProControl should/could be: | johnnyv | ProControl, Control|24, Command|8 | 0 | 11-06-2001 10:45 PM |
