Old 11-12-2012, 08:01 PM
singtall singtall is offline
Default preset file to text converter is here!
check out this post on the eleven rack presets forum:
http://www.elevenrackpresets.com/for...244&#Post24244
Old 11-12-2012, 11:12 PM
AvidEditor AvidEditor is offline
Default Re: preset file to text converter is here!
Very cool.
Old 11-14-2012, 05:02 AM
jimification jimification is offline
Rock ON!!!!! This is a great step forward for the Eleven Rack :)
Thanks for the hard work on this!
Old 11-14-2012, 08:56 PM
Gerry White Gerry White is offline
Almost here, just have to get my head around logarithms.
Old 11-20-2012, 01:13 AM
Holyoli Holyoli is offline
Great ...
Old 11-20-2012, 05:50 AM
The output looks like this. Any ideas on how to use this data?
Code:
Rig Name:      SRV PRIDE & JOY
File:          SRV PRIDE & JOY.tfx
Last modified: Fri, 30 Dec 2011 02:01 PM
Exp Pack:      Yes
Stage 0:
Effect:        Global Params
Rig Vol        -16.6 dB
Volume1        0.0 dB
Volume2        1.9 dB
Tempo          120.0 bpm
Display        8.0
True-Z         32K ohm
Exp Type       Wah
FXc1           8.9
FXc2           8.9
FXc3           8.9
FXc4           8.9
Stage 1:       Volume
Effect:        Volume Pedal
Bypass         No
Volume         10.0
Min Vol        0.0
Taper          Log
Stage 2:       Wah
Effect:        Shine Wah
Bypass         Yes
Position       0.0
Stage 3:       FX1
Effect:        Gray Compressor
Bypass         Yes
Sustain        2.9
Level          1.7
Stage 4:       Distortion
Effect:        Green JRC Overdrive
Bypass         Yes
Drive          6.8
Tone           5.0
Level          8.6
Stage 5:       Modulation
Effect:        Vibe Phaser
Bypass         Yes
Speed          3.5
Depth          5.0
Volume         10.0
Mode           Vibrato
Stage 6:       Amp
Effect:        Amplifier
Output         1.6 dB
Gate           -90.0 dB
Release        10.00 ms
Bypass         No
PreAmp(V1)     7.9
Volume(V2)     4.5
Master         9.4
Treble         7.4
Mid            4.9
Bass           10.0
Pres/Cut       5.8
Bright         No
Amp type       82 Lead 800 100W
Intensity      0.0
Speed          7.5
Tremelo        Yes
Cab Byp        No
Cab            4x12 Green 25W
Mic            Cond 67
On Axis        No
Breakup        0.0
Mid Freq       1.0
Stage 7:       FXLoop
Effect:        Effects Loop
Bypass         Yes
Send           -6.0 dB
Return         2.1 dB
Mix            100.0 %
Stage 8:       FX2
Effect:        Graphic EQ
Bypass         No
Lows           8.4
Low Mids       5.7
Mids           0.2
Hi Mids        3.4
Highs          -2.4
Gain           2.6
Stage 9:       Delay
Effect:        BBD Delay
Bypass         No
Mix            4.6
Fback          0.0
Delay          32.0 ms
In Lev         6.7
Depth          3.5
Mod            Chorus
Fine           No
Noise          No
Stage 10:      Reverb
Effect:        Eleven Stereo Reverb
Bypass         No
Decay          1.0
Tone           8.4
Mix            5.7
Type           Small Plate
Pre-Del        50.0 ms
Old 11-20-2012, 06:12 AM
Sorry but I'm not sure to understand quite well your question
Old 11-24-2012, 09:31 AM
ready for download:
http://www.elevenrackpresets.com/for...4519#Post24519
Old 11-24-2012, 10:06 AM
Ciscokid Ciscokid is offline
Smile Re: preset file to text converter is here!
And it works a treat, just make sure you're running the latest version of Java.
Shame on you Avid for leaving it up to the end users. I think we all expected more from such an established company but I guess we were wrong.
We all got board waiting..
Export markers as text file? peter5992 Post - Surround - Video 3 11-22-2011 06:42 PM
How to export track names in a text file? lapieuvre Pro Tools M-Powered (Win) 1 06-29-2010 09:52 AM
Export timecode in text file :Rob: 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-11-2009 07:29 PM
Export Digibase comments as a text file? rhumphries Post - Surround - Video 2 08-04-2006 05:21 PM
text file thx1138 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-15-2004 05:04 AM
