Sudden latency when recording audio
Anyone please help.
Something has suddenly happened to my Digi 003 Rack, OR my LE 8.0.1, OR my iMac. Suddenly, when recording audio, all the regions end up in the edit window with a latency of 2500 samples. WHY? Have I changed a setting somewhere, not knowing this will be the effect? Someone please troubleshoot with me, because I don't know where to look to find a solution. Per B, in Sweden
Mac OS X 10.5.8, iMac 2.66 GHz Intel Core 2 Duo, 2 GB 800 MHz DDR2 SDRAM, Pro Tools LE 8.0.1, Digi Rack 003 |
Re: Sudden latency when recording audio
Whatz on ur MF?
What Keybeetsss is saying is exactly right: sure sounds like you have plug-ins running on your master fader.
“What fresh hell is this?” - Dorothy S. Parker |
Yep I'll third this. If you've added any plugs to the master fader you're bound to end up with latency issues. Esp if you've added some of the "mastering" type plugs. Some of them add some ridiculous latencies. However when mixing you'll never notice as everything is "delayed". Record with them however and everything gets off.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
Sounds like some of your tracks are coming out from a different analog output. Also, Have you check your low latency?
JS |
Thanks guys, you were of course right, all of you. I have read about this somewhere before, but forgot it. I had Ozone on my master fader...
Well the reason I know is because I've been there. lol First time it happened I was so confused. I had cut a guitar track to a drum track. It was wayyyyyy off. Tried to line it up manually but never could make it sound right. (My lack of guitar skills probably didn't help.) Kept trying things and nothing worked. Don't even know how I figured out. Probably came here and did some research. So now before I hit record I always look at the master fader.
Sudden issue with 003 and low latency | Linusoli | Pro Tools 10 | 0 | 08-27-2013 02:48 PM |
Mbox 2 Pro sudden latency issue | Banana | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-13-2010 07:02 AM |
Sudden latency with Mbox 2 Mini | steve.mastr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-01-2009 03:03 PM |
sudden strange latency on audio recordings with cubase | nincompoop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-08-2007 11:54 AM |
Latency? Recording Audio from FL Studio | Dr. H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-07-2006 08:35 PM |
