Old 09-20-2006, 07:09 PM
PTgeek911 PTgeek911 is offline
Default Low Input level
Ok guys, I have a 6176 as my main preamp and have a few questions. When I get a good level on my 6176 (say Im micing an amp) its not peaking. Now when I look at levels in pro tools it's very low. It has no dynamics (in the sense that the waveform looks like a long, almost perfect rectangle.) Is there a cure for this, or is this just how it works? Im bypassing the compressor. It seems no matter what I try I cant figure it out. Now with my Digimax, I have no problem since its going through digital. Thanks in advanced
G5 Dual 2 ghz
512MB RAM
OSX 10.3.5
HD| 2 TDM 6.7
Old 09-20-2006, 10:14 PM
doopadee doopadee is offline
Default Re: Low Input level
Are you getting the signal into PT from your mic or is it just noise? If the signal from your mic is too low then it's possible that your preamp just has a very low output. Try turning up the gain on your pre and/or using your compressor to get a hotter signal going to PT.
Adam Miele
Pulse Music, NYC
(212) 358-7900
[email protected]
Adam Miele
Pulse Music NYC
212-358-7900
[email protected]
Old 09-20-2006, 10:33 PM
Everything is good. But the signal is low. I dont want it to clip my 6176 just to get a hot signal for pt. If you have any other advice, please let me know!
G5 Dual 2 ghz
512MB RAM
OSX 10.3.5
HD| 2 TDM 6.7
Old 09-20-2006, 11:19 PM
Iain Graham Iain Graham is offline
What's the reference level for 0VU on your PT interface?
I use -18dBFS, and that looks really low on PTs meters. However, that low level is correct, it's just the scaling of PTs metering.
Is your pre metering around 0VU?
myspace . com / iain _ graham
Old 09-21-2006, 08:22 AM
PTUser NYC PTUser NYC is offline
And if your levels are correct, maybe its the source. If all you've tested is distorted guitar, it might look like that. Try a vocal?
Old 09-21-2006, 08:36 AM
robstaman robstaman is offline
maybe this will help
Old 09-21-2006, 11:15 AM
Craig F Craig F is offline
from page 4 of the pdf:
Maximum Output Level +20 dBm
so if you have not re-calibrated your interface from the -18 dBFS that it coms from the factory with the output will clip the D to A converter by 2 dB.
Thank you,
Craig
Old 09-21-2006, 02:04 PM
JGuth JGuth is offline
I. If the signal is clean and quiet you can just adapt to that level scheme and it will still be fine-there are many threads about that.
If you still want a hot level in PT it's hard with calb at -18. I just use the -10 level inputs on my 192 so I don't have to push the output level of my preamps to get hot levels in PT, but I'm trying to back off from that habit-there is no sonic advantage, although I do think the wave displays get grainy if the level is really low.
input monitoring level and record level different Jason1 macOS 8 12-07-2014 10:06 AM
Compressor 3 output level=input level?? JonesH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-16-2009 05:59 PM
Stereo buss level low relative to input level twodb Pro Tools TDM Systems (Mac) 4 01-31-2006 04:49 PM
Input Level vs. Output Level MrFret 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-07-2002 10:15 AM
low level on 888/24 input zev Pro Tools TDM Systems (Mac) 12 02-21-2000 02:16 PM
