Old 10-04-2022, 07:49 PM
massivekerry's Avatar
massivekerry massivekerry is online now
Default Re: 2022.9 Can't grab MIDI notes
It seems a lot better than in prior versions. But I ran into it twice, working 10-12 hour writing days (new sessions, based on my template) every day since Thursday. Only twice. Clicked the 2 tracks into "Samples", changed my velocities, switched it back to Ticks. All good.
But not totally fixed. Kinda sad.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 10-06-2022, 02:41 PM
midnightrambler midnightrambler is offline
I've just run into this, trying to covert audio into MIDI by dragging down onto an instrument track. Also occurs if you use the Massey DRT to do the same thing. A close and re-open seems to sort it. Does it on both my computers. (I'm on Mojave on both)
Old 10-07-2022, 09:25 AM
daeron80 daeron80 is offline
I solved it by switching to Logic for MIDI work. Never going back.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 10-07-2022, 09:43 AM
smurfyou smurfyou is offline
Have you tried running both with Aux I/O going into PT? Just curious.
~Will
Old 10-10-2022, 10:29 AM
No, so far, I've only used Aux I/O for integrating Zoom with PT.
David J. Finnamore
  #16
Old 10-12-2022, 11:29 AM
bluskiff bluskiff is offline
yes the changing from ticks to samples worked. I have tried the AuxI/O with ableton running in ableton link. So great to be able to bounce ableton sessions right into protools.
  #17
Old 10-17-2022, 06:53 PM
take77 take77 is offline
Originally Posted by lesbrunn View Post
+1 for samples instead of ticks. I believe this only happens in older sessions opened in 22.9. This workaround has also solved ARA issues for me in older sessions. Old sessions don't seem to translate well. A cursory midi test in a brand new 22.9 session here didn't seem to produce those known midi issues.
Most recently, I created a brand new session after re-installing 2022.9.
The first thing I did was drag & drop a MIDI drum loop onto a track.
Double clicked the clip to open the MIDI editor and the notes were frozen right off.
Glad for the ability to change to sample mode but unbelievable timing that it happened right after re-installing 2022.9.
It never happened right away like that during the previous install until I went back to .7 momentarily to test another issue.
I've since deleted the prefs folder in Windows hoping that would help me with a couple other separate issues.
I'm starting to view switching to sample mode as an edit option like momentarily switching between Slip & Grid mode as a workflow instead of a bug.
I'll do some more tests (try to work as normal that is) in the new session tonight and let you know how it goes.
A rough sea makes a smooth sailor.
Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD
Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6
Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory
  #18
Old 10-28-2022, 01:17 PM
chadwahlbrink chadwahlbrink is offline
In 2022.10 - I'm still running into this bug with selecting MIDI notes. It happened today in a session where I used the "audio to midi" function. Every time I would use that, the resulting MIDI clip's notes would be frozen.
I'll have to try the workaround by switching to sample mode and back. I also found that if I consolidate the clip, it works great.
I'd love to see Avid fix the root issue of this problem though!
Thanks,
Chad
Chad
System Details
MacBook Pro (16-inch, 2021)
Apple M1 Max
64GB Memory
MacOS 12.6
Universal Audio Apollo 8p
Pro Tools Ultimate 2022.7
  #19
Old 10-28-2022, 03:00 PM
No mention of a fix in the .10 release notes.
  #20
Old 10-28-2022, 09:18 PM
Dizzi45Z Dizzi45Z is offline
I've been working a ton in MIDI and I have not seen any issues in 2022.9-2022.10 until today.
When this issue happened today, I couldn't fix it from switching time/sample based on the track. I restarted the session and even then still had some issues, but somehow it started working again.
I do really hope they find the root of this problem as this one is a very frustrating one when it happens.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Can't select MIDI Notes after Quantizing them in 2022.6 [PT-289219] Dizzi45Z Pro Tools 93 10-18-2022 08:17 AM
START CLICK GRAB (PC) CTRL CLICK GRAB (Mac) Kris75 Tips & Tricks 2 07-23-2013 09:53 AM
midi copy/duplicate: 7.4 can't grab 1st quantized note glankrudolph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 12-16-2008 07:33 AM
Recording Midi notes and keeping existing notes during record Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2008 09:40 AM
GRAB the MIDI KeyBoard in the Edit Window- scroll gollywillickers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-12-2006 11:41 AM
