please explain... digital cables (s/pdif)
ok so i know that a s/pdif cable has to be 75 ohm, ok no problem i know that jitter is a bid deal and you have to be aware of . but could someone please explain to me why i should buy one of these cables instead of the other apogee 3.3' dual rca 75 ohm (50 bucks): http://www.sweetwater.com/store/detail/WERR1.0/ hosa 3.3' dual rca 75 ohm (9 bucks): http://www.sweetwater.com/store/detail/DRA501/ thanks for any help. -jeff
www.sonicdisorder.com |
Re: please explain... digital cables (s/pdif)
Heck, I've been using a pair of those stock RCA cables that you get when you buy a CD or DVD player without any problems....
Paul Peterson Sound Director The Old Globe San Diego, CA |
So what's the difference between Professional Potting Soil and the amatuer stuff ? Besides, you want the fashionable ones don't you.
" What hump?" |
well, i actually did think that someone would tell me that there is some kind of advantage.
something like less gitter or something else that isn't measueable then there would be a big debate that no one would be able to prove.
The answer is simple.
Non-professional cables will work absolutely fine if the length is limited. But if the distance between two equipment is far enough, say 10-20 metres, you will need a bloody professional cable. Do not compromise on the cost then. A longer cable with poor quality cores will definitely add jitters or stop recognising the digital device intermittently. But as long as your length does not exceed 2-3 metres, you can save your bucks. |
great
thank you, Gaurang -jeff
Some expensive cables (Planet Waves/Proel) have a lifetime warranty. They also have far superior connectors to HOSA, which represents the other end of the scale.
G5 Dual 1.8 /1.5 Gb Ram OSX 10.4.7 PT LE 7.3 cs1 DIGI 002 Waves Ren Sony Bundle Soundtoys-arama NI Komplete 3 |
Digidesign Digital 192 I/O internal 50 pin cables | Alex Casey | Pro Tools HDX & HD Native Systems (Mac) | 28 | 11-07-2013 06:42 AM |
Recommended Adat Digital Cables?... | Icemaster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-01-2005 11:54 AM |
s/pdif cables? | Brad Ferguson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 05-16-2003 08:01 AM |
S/PDIF cables? | Forrest77 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-07-2002 07:29 AM |
s/pdif cables - not regular RCA cables? | j20056 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-26-2001 11:51 AM |
